Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Industrial Hobbies (Support forum)
Industrial Hobbies (Support forum) Discuss Industrial Hobbies Milling machines and get direct support here.
Old 05-09-2007, 08:18 PM
Shepard is on a distinguished road
chasing .003 backlash on x&y
Hello,
I'm new to cnc and have put together an IH mill and CNC kit. Everything is together and working but I have approximately .003 backlash in my x and y axis. I followed the directions as far as I know, including the 1/4 turn on the ballnut and just flattening out the bearing retainer washers during setup. The gibs are in and I've tried light and heavy adjustment on them. Anyone out there with similar experiences that got it worked out?
Thanks, Shepard
Old 05-09-2007, 09:16 PM
davo727 is on a distinguished road
Hi, What style ballnuts are they? Are each each axis one 2 pass nut or 2 single nuts together on an adjustable mount? Have any pictures of them? Dave
Old 05-10-2007, 06:49 AM
Gold Member
InspirationTool is on a distinguished road
For backlash, you need to check both the ballnuts AND the thrust bearings.
I suspect the latter is your problem.
-Jeff
www.JeffAlbro.net/cnc/
Old 05-10-2007, 08:38 AM
I spoke with Gene, who is always very helpful, and it is likely I didn't get the ballnuts set up properly. With any luck I'll be up and running within the week.
davo727 if I've used the attatchment feature correctly the picture is from IH's website and is the ballnut used.
Old 05-10-2007, 05:58 PM
after fiddling with the ballnut and bearings I have it at .00025. But the motor is warm so I think the bearing are a little tight.
Old 05-10-2007, 07:00 PM
Ron111 is on a distinguished road
I know that stepper motors can run a little warm. I have not worked with servo's so don't know about them.
Ron
Old 05-16-2007, 08:44 AM
Loadedagain is on a distinguished road
what did you end up doing to the ballnuts to get the backlash sorted?
dad used to say... "once is ignorance. the second time you're stupid!"
Old 05-16-2007, 08:54 AM
HAving never even been in the same room as a mill much less adjusted a ballnut I had put NO tension on the nut. Gene suggested I loosen the axis up, then use a small allen wrench and pull till the allen wrench slips out of the collar and then tighten maybe a tad more. That worked for me. As a novice I misunderstood the website instructions but this worked and now backlash is virtually gone.
Backlash N4NV Linear and Rotary Motion 17 03-28-2007 08:37 PM
Chasing Threads Help needed Farmers Machine Milltronics 18 03-12-2007 03:50 PM
Servo idea - elimated backlash - zero backlash ! synthetiklone Linear and Rotary Motion 6 12-06-2006 01:35 PM
What is backlash ? ynneb FAQ of CNC Machine building 0 08-16-2004 07:27 PM
Backlash? mgamber Gecko Drives 7 04-25-2003 04:12 PM
