Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Industrial Hobbies (Support forum)
Industrial Hobbies (Support forum) Discuss Industrial Hobbies Milling machines and get direct support here.
Old 04-08-2007, 10:40 AM
QSIMDO is on a distinguished road
DC motor suitability?
I can't help it...I'm a sucker for shiny, techy stuff, and these motors just get me drooling.
http://www.robotmarketplace.com/mark...magmotors.html
Aside from being quite a bit more expensive than the 3 phase, 2hp Leeson and a VFD, how suitable would the DC be for powering an IH mill upgrade?
Torque figures are insane.
And you guys not using the quill feed, there's your belt drive with a splined pulley on the exposed upper section of the quill.
Hmmm.....
Old 04-08-2007, 11:47 AM
Al_The_Man's Avatar
I can only see these being used for a VERY short duration, When you have a motor that is not much bigger than a large fist, rated at 285amps and is 2.5kw!!
The heat produced would have to go somewhere if used for for more than a few minutes.
Old 04-08-2007, 02:27 PM
I'll bet Bob Warfield could adapt a computer water cooling system....the gauntlet is down!
Old 04-09-2007, 12:10 PM
BobWarfield's Avatar
BobWarfield is on a distinguished road
Scary!
Those motors look to me more like potential servo candidates than spindle motors. I would stick with the 3 phase Leesons for your spindle use.
Best,
BW
Old 04-12-2007, 09:47 PM
jamiechi is on a distinguished road
I think using a servo for the spindle is a good idea. How about cnc'ing large threaded holes and other complicated holes?
I wouldn't use these motors anyway. They are wound for low voltage and are designed for running robot wheels from batteries. I checked the motor manufacturer's web site and they have some motors that run on 90 volts or more and run as high as 6000 rpm. Step that up 2 or 3 times with pulleys and you should have a good spindle speed for Aluminum.
I've done some work with aluminum with Sherline's high speed 10,000 rpm spindle. Aluminum cuts really nice and the motor is only around 1/3 hp.
Maybe I should mount my Sherline spindle on my IH machine.
Old 04-15-2007, 10:14 AM
http://truetex.com/dcdrv.htm
A DC swap on a Bridgeport using a cheap treadmill motor and the owner seems more than satisfied.
Problems with motor stalling due to motor/lead screw alignment Bimmerkc1 DIY-CNC Router Table Machines 3 01-24-2010 06:12 PM
Stepper Motor Suitability? unicorn13 Stepper Motors and Drives 9 01-08-2007 04:36 AM
Suitability of Torchach CNC mill for education 44-henry General Metalwork Discussion 10 05-19-2006 01:39 AM
servos motor controled by stepper motor driver? mike10 Servo Motors and Drives 1 01-03-2005 05:05 PM
MOTOR MATH? with motor E642 in hand Bloy2004 Servo Motors and Drives 3 07-03-2004 07:03 PM
