Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Industrial Hobbies (Support forum)
Industrial Hobbies (Support forum) Discuss Industrial Hobbies Milling machines and get direct support here.
Old 04-07-2007, 03:35 PM
davo727 is on a distinguished road
Some R45-7045 mill mods
Hello, I was trying to decide whether to post in the benchmill forum or here when another member who has an IH mill asked me to post my mods in this forum due to the similarity between the Ih mills and the r45 clone and Zay 7045 mills. The mods should apply and benefit any of the brands. I went with a zay7045 from wholesale tools because I was able to pick it up at their store here in houston area. One thing I didnt like were the bolts that went down through the column and threaded into the base. Not good if you are gonna loosen and tighten a million times during tramming fun. I decided to drill the threads out of the base and run 5/8 grade 8 bolts up through the bottom with nuts on top of the column flange. First I reinforced the area the bolts go through by adding a steel plate underneath. It is .750 thick , 1.5 in wide and about 6.5 in long. They are secured to the base by a countersunk 3/8 bolt in the middle and two 1/2 in dia setscrews that are threaded all the way through the base and the .750 strap and then there are jamnuts on the bottom you can see in the pic. The setscrews are ground flush on the top surface where the column sits. The 5/8 bolts each have a tab welded on the head that keeps them from spinning. Dave
ID:	35011   Click image for larger version
ID:	35012   Click image for larger version
ID:	35013   Click image for larger version
Old 04-07-2007, 03:45 PM
The capscrews that are in the column flange are 1/2- 13 thread and allow me to figure out the column tram error in about 5 minutes. I am going to grind the bottom of the column to eliminate the error after I reassemble the table and z-slide. The gearbox doesnt have to be installed. The magnetic base can be attached to the Z slide and the indicator slid up and down on the back and side of a right angle block on the table to figure out the error when moving the vertical up and down.
Old 04-07-2007, 04:03 PM
Hi, Next I filled the base with Epoxy concrete to stengthen it , add weight and dampen vibration and chatter. I posted the details in the engineering forum here on cnczone in a big thread about Polymer concrete construction in machine tools. I made a frame insert from 1/4 thick by 4 inch mild steel welded together. It drops down into the base and I drilled and tapped the base for 4 3/8 bolts to secure it. It keeps the epoxy in the areas that I want it until it cures. You can see I boxed around the bays where my column attach bolts go so no mix goes in those areas. I want to keep access to that area. There is also plumbing installed for the y axis way pressure lubrication. I put in pipe inerts for the mount bolts from the base to the bench to go through. Also a tube for a large bolt to go up through the base and column.
ID:	35016   Click image for larger version
ID:	35017   Click image for larger version
Old 04-07-2007, 04:16 PM
OK starting weight of base 100 lb. Steel frame 15 lb. Completed weight 180 lb. So 65 lb of epoxy, sand, rock mix. There is also a pipe embedded in the Epoxy mix that the 1.25 in dia bolt goes through. The vertical column that bolts here will have the bottom 5 or 6 in filled with Epoxy mix with another pipe insert for the mega bolt. A plate and nut on top of the Epoxy and crank down the nut should give some huge clamping force to hold the base and column together. The big bolt is 4140 B7 steel alloy threaded rod from grainger. The B7 rating is between 100 to 120K psi tensile strength. The rod was about $33.00 for a 3 ft pc. Im gonna have to go buy a 1 3/4 in socket for that darn big nut
Old 04-07-2007, 04:21 PM
For all the details on doing the epoxy fill go to this thread http://www.cnczone.com/forums/showthread.php?t=30155 I think my part starts somewhere around page 47 http://www.cnczone.com/forums/showth...=30155&page=47
Old 04-07-2007, 08:15 PM
Runner4404spd is on a distinguished road
wow! really nice work. what do you plan on doing with it that your reinforcing it so much? i realize that all the extra mass adds alot in terms of vibration damping although i wonder if you need to get more epoxy and rock further up the column to really stiffen it. i guess before i go to all that trouble i will be buying a full up cnc mill from Haas or hurco or someone. but definitely keep up the good work.
Old 04-07-2007, 08:51 PM
Hi, Thanks, Im going to do a full cnc conversion on this. Im figuring out the design for the Z ball nut mount right now. After that I will be able to see how far up I can fill the column without interfering with the ballscrew. I plan on using it for some motorcycle parts and auto stuff. I just figure I am going to improve it wherever I can without spending a fortune. A haas or other vmc is not in my budget so I plan on making my mill as good as I can. I dont see this as work or trouble, I am enjoying working on it. Dave
Old 04-09-2007, 12:20 PM
BobWarfield's Avatar
BobWarfield is on a distinguished road
Very cool work, and nicely done!
Did you have a chance to use the mill much before you tore it down? I'm wondering if you'll have any basis on which to compare the "before and after" improvements?
I am seriously tempted to do the epoxy fill as I work out my own IH CNC conversion. I have two mills and plan to leave the original operational manually as I work on the second. This will give me some opportunity for before and after tests.
It also lets me use the original mill to do machining on the second one as needed.
Best,
BW
Old 04-10-2007, 02:15 AM
Hi Bob, Thanks. I just got the mill in feb and just played around milling a few aluminum pieces before tearing it down so I wont have any real before and after comments. I think as designed the bases have a lot of potential of flexing and twisting and think the epoxy fill will prevent any kind of movement. Filling it wasnt that hard. Simpler methods could be used to section off the base to contain the epoxy than the way I did it. You could use relatively thin aluminum sheeting attached and sealed to the base with 5 min epoxy. Also if your not using studs from the bottom like me then you dont have to section off that area. Then fill with epoxy concrete mix. Its great you have an extra mill, you avoid the chicken and egg problem. I have to put mine back together to make the mounts for the ballscrews and bearings. I assume you have your manual mill trammed good so you can make good parts for your conversion? I made another comment in the cnczone suggestion forum that this IH board should be for all the square column IH, Zay7045, R45 clones, not just IH marketing. Theres no good info for these in the Benchmill forum, just mini x1,x2,x3 stuff. Later, Dave PS--- I have some more mods to the basic mill to show in a few days. Then will get started on some of the cnc stuff.
Old 04-10-2007, 06:03 AM
Cruiser is on a distinguished road
This is fine and good i spose but i had about .015" twist in my base needing pulled out when i fitted it to the frame of my table. will yours still move ?
Don
IH v-3 early model owner
  #11   Ban this user!
Old 04-10-2007, 06:33 AM
Yeah I see your point if the base is twisted you wouldnt want to cause it to be locked into a twist. You should be able to shim it and clamp it down square and true upside down on a bench and then fill it and it should stay straight at that point. I know the Y- axis ways on mine are nice and straight and flat with no twist.
  #12   Ban this user!
Old 04-10-2007, 07:46 AM
philbur is on a distinguished road
I wouldn't bet on it staying straight.
Regards
Phil
shoptask 3/1 lathe/mill assembly and mods Bloy2004 Shopmaster/Shoptask 131 01-24-2008 08:06 PM
Jewelers X2 mini mill mods. copper3416 Benchtop Machines 7 04-01-2007 05:36 AM
helpful mods for a grizzly mill omegaghost Benchtop Machines 4 02-05-2007 10:57 AM
Mods to my mill Richards Industrial Hobbies (Support forum) 4 11-02-2006 01:51 PM
