Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Industrial Hobbies (Support forum)
Industrial Hobbies (Support forum) Discuss Industrial Hobbies Milling machines and get direct support here.
Old 01-29-2007, 06:15 PM
klondikebike is on a distinguished road
Folks satisfied with their IH mill?
Having spent quite some time researching a bench top mill for my shop, it looks like the IH mil offers the best value for the money in the Chinese mills. Are people generally happy with these? Looks like the new run will have some improvements. Are these a better value than the Rong Fu units? I just spoke with Aaron, and he seems like a stand up fella.
Paul
Old 01-29-2007, 08:12 PM
BobWarfield's Avatar
BobWarfield is on a distinguished road
I love my IH mill and have done quite a lot with it. You can see the projects on my web site:
www.cnccookbook.com
Aaron is a stand up guy, and extremely sharp about these mills and machinework in general. Unfortunately, he is moving on. Haven't chatted with the new owner yet.
Best,
BW
Old 01-29-2007, 09:06 PM
bohica is on a distinguished road
My mill is not yet running, so I cannot yet comment on the usability or utility of the IH mill in operation. But I hope to do so shortly,
What I did find is that this is akin to turning a sows ear into a silk purse. Not that this is isolated to the IH mill...you will find these problems throughout the Asian mill industry.
Like you, I did a lot of research and reached the conclusion that the IH mill represented the most bang for the buck. It still does.
However, you need to be prepared for potential significant challanges. Here are some I faced. 1.) The base of the square column was never milled, out of square by .080 in two directions to the ways. 2.)Likewise the top of the square column. 3.)The X axis gibs had no means of lubrication. Oh, they had lube fittings in the table, providing a lube point for the side of the gibs that never move. Gawd, what were these guys thinking? 4.)The Z axis ways were concave in the x axis direction by .005 on each side.
Not that I would, knowing this, not buy this mill. I knew there probably would be challanges. Nothing that some old fashioned American inguinity couldn't overcome. Got mine trammed quite nicely, within <.0005 on all but one axis. This is the biggest, baddest mill available in this class. All of these mills suffer some quality problems of varing degrees. But there ain't no other options.
"To mill, or not to mill, that is the question".
Old 01-29-2007, 09:15 PM
wildcat is on a distinguished road
Ok - if I was going to do it all again...
If I was going CNC route as I have I likely would purchase another IH along with the CNC kit after comparing it to both the bigger Smithy CNC (that's more money though...) and Tormach (plug'n play instead of fiddling for a couple of months).
If I was going strictly manual I would not get one of these mills again. I might have been unique in this regard but I just did not feel the quality was all that great amongst other reasons that are related to the work I do. I would most likely get a Grizzly mini-knee mill if I was going to go the manual route. Please note that I have one of the older style - not the most recent one with ground ways and reasonable access to the head retaining bolts.
Don't get me wrong - I don't regret getting the machine I did. It works great. But, if I was starting again knowing what I know now I might do things a little differently though not necessarily better.
In short I am very satisfied but it has taken some time and work to get there.
Best of luck in your choice.
Old 01-29-2007, 10:03 PM
fireguy976 is on a distinguished road
Im also thinking of the I/H square column mill, joined this group to find out more about them. As I/H has their own group, maybe they are ok.
Looking for as much feedback, both good or bad, as possible.
What have you heard about the sale of the company? Also can still get a discount if ordered before Feb 15.
Regards,
KJ
Old 01-29-2007, 10:40 PM
Thanks for the feedback guys. I realize that a chinese mill will always be a chinese mill, but at least Aaron has done some homework on these, and his support appears to be second to none, which is where these (Chinese) mills seem to fall short. It looks to be head and shoulders over the Rongfu and their spawn.
Are the sagging issues with the head addressed with new changes?
Wildcat, how is the quality on those mini kneemills from Grizzly? The other option i was thinking of is one of those from the Busy Bee guys here in Canada. For my needs, a power feed on the Z axis would be ideal.
Old 01-29-2007, 10:53 PM
Regards,
KJ
Old 01-29-2007, 11:08 PM
Standard disclaimer here... I have never used one but I have seen them in their showroom. While the table is smaller and there may be less travel (not sure about that) if I has choosing a manual mill and my IH mill as it was when it was manual was put next to one of these I would choose the Grizzly without hesitation. Many because of the ease of motion, appearance of ways, MUCH wider ways (even though the Grizzly has a smaller table), additional details such as way wipers, and better way protection as well as general cosmetics. A clinching factor would be to hear the mills run. My gear head IH mill requires earplugs. Compare this to the HF round column belt drive mill for example (a cheaper mill) which is very quiet. Now, gearheads can be quiet... my Grizzly gearhead 13x40 lathe is very quiet. Not sure why the IH gearhead is so loud. Now granted, most of the stuff that I have done and likely to do is fairly small so the huge size is not that important in general. Now, I have trued a motorcycle wheel and for that there JUST barely was enough Y travel.
If you are going to convert to CNC the IH is a great kit though as you know the company is changing hands so that's a big unknown.
You mentioned talking to Aaron. I can absolutely say the reason I got the IH conversion kit is because of the time that Aaron spent with me. I had considered cutting my losses after receiving my mill and getting a Tormach. However, I took a gamble and have been happy after converting the mill.
I do hope that the new owner of IH spends some time to improve the documentation and written specs. That is one place where Tormach has IH beat. Even if the specs are not as good (don't know that personally) the quality and thoroughness of written demonstrates a great deal of professionalism. This difference is hard to over look when considering a purchase.
Sorry for the rambling.
Old 01-29-2007, 11:45 PM
I think people's experiences have varied quite a lot with these machines. Mine came trouble free. I cleaned it up, trammed it in, oiled the ways, and voila, it just worked. Travel on all axes has been very smooth, gearbox noise is not objectionable, I can hold decent tolerances, I take pretty heavy cuts, etc.
Others have reported issues, particularly with Z-axis smoothness as the head is cranked up and down. In some cases it has been really bad. I read this sort of thing about every brand of Asian machine out there, BTW, including Grizzly, Jet, and you name it. I'm looking for a bigger lathe, and there is someone on some board that will bash each and every one of the brands all the way up to $10,000 machines. Try this guy on Jet lathes (which are expensive), for example:
http://www.makeitsimple.com/sections.php?artid=14
Meanwhile, the "I must have Old American Iron" contingent will happily prattle on about how they've avoided the Asian nemesis, until you read the fine print: new spindle bearings ($300), rescraped the ways ($1000), replace XYZ hard to find part ($339), found 0.020" backlash in quill, Y-axis has cross play of 0.003", yada, yada, yada. I'm collecting a list of these anecdotes because I'm considering rebuilding a Bridgeport Boss or Tree at some point. From what I can see, there is no free lunch!
There was another fella on here all hot and bothered about problems with his IH. He was determined to go buy a Hurco because they don't have problems. He's over on the PM board as we speak complaining about the Hurco dealer and thinking maybe Haas is better after all. You can read all day long on those boards about issues people have with brand new Haas and Hurco machines costing zillions.
My point here is that if you are going to buy a machine tool, you are probably going to have to do some work on it almost no matter what if you insist on high enough levels of performance or cosmetic appearance. Even just routine maintenance requires attention not unlike this other work. Adjusting your gibs properly would be one example as would properly squaring and tramming a machine in. Some complain about it, others (especially the Old Iron contingent) view it as part of the fun. I’m not saying you should excuse unreasonable quality, but let’s be real about what we’re getting here for this kind of money, and let’s also expect virtually all machines to need some TLC.
The new IH machines reportedly have ground rather than milled ways. I would expect that to help quite a bit, but I don't think I have yet heard a report from anyone that has one of them, so who knows? I also don't know how to calibrate whether I just got lucky, or whether quality has steadily improved and ordering a later machine gets you a pretty nice deal.
In terms of what to do when going manual, it is an interesting question. Given my luck with my IH, I would really have to see one of these Grizzly machines to be personally convinced. It sure looks to me from my research like Grizzly charges a significant premium, though people do swear by their customer service.
Best,
BW
Old 01-30-2007, 12:04 AM
Bob reminded me... I should add that the problems that I had with the mill in manual operation centered on the quill. It was garbage. To perform drilling and such I had to crank the head up and down. But I had to have the gibs so tight (to keep the head square) that I was either going to build a serious left arm or I was going to have to add a motor to raise the head.
I didn't get the impression that Grizzly charged much of a premium when I bought their lathe (I also considered the Enco version). The enco version was a few hundred less but had a lower maximum speed. For me it came down to "a bird in the hand vs. a bird in the hand." In other words, I had seen the Grizzly - it was a known quantity - but I had never seen the Enco. I have never talked with their customer service. However, they did include a real manual in real English. I mean, come on Chinese importers - can't you spend a few days writing a decent manual? HF seems to be improving a bit in this area.
klondikebike - you DID ask for as much feedback as possible
BTW: Be sure to checkout Bob's website he posted. It is fantastic!
  #11   Ban this user!
Old 01-30-2007, 12:09 AM
klondikebike - BTW: What would you like to be doing with your mill at first and what would you like to be doing in the future?
  #12   Ban this user!
Old 01-30-2007, 09:36 AM
Gentleman, thanks for all the feedback. Its great to get lots of honest opinions.
Wildcat, i have a bike frame building (TIG) business, and i am upgrading my tube mitering system, and for that i need a mill or mill/drill. Basically, it will be a glorified drill press, as it will be just holding the fixturing, and a hole saw. I can certainly see myself using it for milling parts down the road, but its primary use will be the tube mitering. The critical distance on it is 16" min. from spindle to table, for fixture clearance. The IH has this in spades. The large table is nice, as i will have a 8" rotary table and a large vice mounted permanently. The Grizzly and the Rongfu units look god, but the IH looks better.
Cheers
Paul
Home-Brewed CNC Bench Mill Using Siex X2 Mini-Mill Head fignoggle Benchtop Machines 18 05-11-2009 11:11 PM
Hi folks, just want to say hi and....that slowtwitch General Metal Working Machines 5 07-26-2006 08:02 PM
What are folks using for home & limit switches? rustyolddo General Electronics Discussion 21 07-18-2005 05:01 PM
sign folks and their software? Crushmonkey General CNC (Mill and Lathe) Control Software (NC) 0 05-21-2005 02:57 AM
creative/ingenius folks here!? need help jbbaird CNCzone Club House 4 11-01-2003 10:46 PM
