Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Industrial Hobbies (Support forum)
Industrial Hobbies (Support forum) Discuss Industrial Hobbies Milling machines and get direct support here.
Old 01-14-2007, 09:11 PM
dnelso is on a distinguished road
IH Engraver
Harbour Freight makes a cheap engraver that spins 15000.Cost $79 dollars.
ID:	29593   Click image for larger version
ID:	29594   Click image for larger version
Old 01-15-2007, 05:50 AM
Aksess's Avatar
Aksess is on a distinguished road
Great idea. I have one of those and never thought of using it as an engraver on a machine
Old 01-15-2007, 09:50 AM
wildcat is on a distinguished road
Sorry, but I don't recognize this item. I found the following at Harbor but it does not seem to have the same specs. Could you post the item number or link to tool you used?
http://www.harborfreight.com/cpi/cta...emnumber=47869
How long have you been using this engraver? Any signs of the bearings giving out?
Old 01-15-2007, 12:40 PM
philbur is on a distinguished road
Its probably this one:
http://www.harborfreight.com/cpi/cta...emnumber=40432
It would be interesting to know how durable it is for continuous operation.
Regards
Phil
Old 01-15-2007, 03:58 PM
Philbur is correct.I have about 20 total hours on it. I only cut about .020 deep and it seems fine.There is endplay in it when its new but has not gotten worse.
Old 01-15-2007, 10:38 PM
BobWarfield's Avatar
BobWarfield is on a distinguished road
Nice job!
I see you have a powered drawbar too. Love mine!
Best,
BW
Old 01-16-2007, 07:01 AM
Bob i saw your vid on your website and had to have one.Made some small mods,added bronze bushings on the top plate.Its 3/4 wider for spring clamp clearance.
Later
Old 01-16-2007, 09:06 AM
Nicely done too!
I also like your mount for your cooling system. What's the plate behind the column, counterweighting system? It also looks like you've upgraded the motor?
Best,
BW
Old 01-16-2007, 03:16 PM
The coolant mount is the one Aaron sells with the kit.The plate in the back is notched back so the weight of the mill sits on top of the legs that go to the floor.I have drawings for the engraver bracket and the base plate for the power drawbar.I only have them in iges format.If someone wants to convert them to dxf they can post them here.
Old 01-16-2007, 04:07 PM
Hmph - I didn't get a coolant mount with my kit...
Could you post the IGES files? I am sure that someone can convert them.
  #11   Ban this user!
Old 01-16-2007, 04:20 PM
Runner4404spd is on a distinguished road
you can send me the iges to
jerry@supperiordesignconcepts.com
i'll convert the file and post it tonight.
  #12   Ban this user!
Old 01-16-2007, 04:36 PM
I will post the files later tonite.
