Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Industrial Hobbies (Support forum)
Industrial Hobbies (Support forum) Discuss Industrial Hobbies Milling machines and get direct support here.
Old 11-06-2006, 07:06 PM
kimoyo is on a distinguished road
Z-axis preloaded ballnut?
Aaron gives you a choice for your z-axis ballnut, you can get single circuit preloaded or double circuit. He recommends the double circuit eventhough it has a backlash of around 0.002 because the forces on the z-axis can exceed the preload and cause issues.
Are these forces from the weight of the head?
If the forces are from the head weight, could we add gas springs like on this syil
in a similar way to the z-slide of the ih mill?
Then put preloaded ballnuts on the z-axis without any issues? Thanks.
Old 11-06-2006, 10:13 PM
Gold Member
Adobe Machine is on a distinguished road
Or a third option.Re-load the primary ball nut ( the one with the flange), I believe IH uses Rockford double ball nuts ..I used .0002 and .0003 oversize, every other one. This means that you are not tensioning the following nut so tight to eliminate backlash that it causes u..m..p ... on acceleration.You really can get down to .0003-.0005 back lash with out a lot of ball screw friction.
Have you bought a mill yet ?
Adobe (old as dirt )
Old 11-06-2006, 10:30 PM
wildcat is on a distinguished road
Don't the forces that are being considered in ballnut choice have to deal with machining forces?
I went the recommended route figuring the .002 backlash is going to be pretty small compared to the contours encountered during 3D milling.
Old 11-07-2006, 10:18 PM
Moderator
JRouche is on a distinguished road
The pre-loaded ballnuts use a belleville washer spring pack to load the nut. The spring is rated at a certain load.
Once the load rating is passed (weight of the head or accelerating/decelerating forces) the nut halves (spring pack between the two halves) move closer together (or apart) causing backlash. JRouche
Old 11-08-2006, 12:38 PM
Adobe - I decided to go ahead with the IH mill and kit.
Wildcat - I wasn't even thinking about 3D milling which would be harder than the flat sheet milling I was planning on doing. I'm just trying to get the best performance from the kit.
JROuch - Thanks.
I'm still not sure what the best thing to do is.
If the 250lb weight of the head could be compensated (and cantilevering helped) for by the gas springs could the preloaded ballnuts be an good option?
If I get the double circuit and backlash was an issue, I believe Adobe is saying I could reload the nut with oversize balls and push the backlash down even further.
Thanks.
Old 11-08-2006, 07:32 PM
I had a very good conversation with Aaron today where he explained to me whats going on.
The issue with preloaded nuts isn't the weight of the head. The reason people install the gas springs is when their motors are too weak to lift the head which is not an issue with the IH kit. The issue is when machining thick amounts of material you may WANT more than 600lbs (the load limit of the spring) of force pushing down. So if you want more than 600lbs pushing down the heavy head actually helps, lol.
He also explained that the backlash could be anywhere from 0 to 0.002 but that he always puts the outer rating on his website. So my backlash might be much less.
Adobe - Thanks for you help and suggestion. Aaron actually does use oversized balls but I'm not sure if its in your configuration.
