| Industrial Hobbies (Support forum) Discuss Industrial Hobbies Milling machines and get direct support here. |
| cat spindle/quill for ih mill does anyone know if there is a cat 30 or 40 spindle/quill for the ih mill? |
| Why not call Aaron Moss and ask him? I'm sure that he would be willing to tell you what's probable in contrast to what's merely possible. |
| i've spoken to aaron already and got an answer. i assumed because you mentioned cat spindles in your thread referencing discussion with aaron you may know something else. i have a ton of cat tooling i'd love to use, but at this point it doesn't look like the ih mill will be the new home. unless someone else knows something |
| Anything's possible, but the idea is entirely improbable. You'd have to replace the entire head and the final cost would be several times that of the mill itself. The diameter of a CAT30/40 taper is substantially larger than that of an R8, which means a much larger spindle, and hence much larger bearings, pulleys, etc. You've probably already figured out that in the machine tool world, price goes up exponentially as size/speed go up linearly. |
| My manual RF40 clone came with either MT3, R8 or ISO30, All as no cost options. The quill diameter was the same in all cases. I took the ISO30 and soon wished I hadn't. Regards Phil
| I could swear that KB tools has a R8 to cat adapter. I dont have with me but i will try to check tonight. Randy |
| As the CAT30 has a larger diameter than R8 it would have to be an extention type adaptor and this would make it rather flexible, reduce your Z envelop and negate the main reason for using a CAT, which is the possibility of automatic tool changes. Regards Phil |
| Also you would need to be very inventive to overcome the drawbar conflict. R8 requires a drawbar so does the CAT!!!!!! Phil |
| Still these collets were held in with a nut at the end tg100 was the collet number. I have seen the end of these in home shop machinist alot. If I could get away without changing drawbar it is tempting especialy with a drawbar pushing the top of the head out of my reach. Randy |
