Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Industrial Hobbies (Support forum)
Industrial Hobbies (Support forum) Discuss Industrial Hobbies Milling machines and get direct support here.
Old 03-15-2006, 09:06 AM
Runner4404spd is on a distinguished road
IH mill stand
is it worth buying the mill stand or should i just build my own? i could fill the mill stand with concrete if necessary if it will save me a lot of fabrication.
Old 03-15-2006, 11:19 AM
mcarvey is on a distinguished road
When I bought a Grizzly G1007 (for non cnc work) I got the G5944 metal stand for it. It works fine if you're not using a flood coolant system. When I got my IH mill (for cnc work) I opted to build a table that was appropriate for flood coolant. It was easy to do, relatively inexpensive, and I was able to tailor it to my needs. I would not recommend use the metal stand if you ever plan on using flood coolant.
-Matt
Old 03-20-2006, 03:51 PM
Zumba is on a distinguished road
The IH mill stand is pretty crappy. Let's leave it at that. The IH mill itself can be turned into a pretty capable CNC machine, but the stand is hopeless.
