| Industrial Hobbies (Support forum) Discuss Industrial Hobbies Milling machines and get direct support here. |
#13
| The IH mill has some fit and finish issues, most of which don't matter if you're converting it to CNC. I'm currently sanding mine down, reapplying bondo, repainting it, and replacing some of the cheap hardware. Shouldn't cost more than 30 bucks. |
#14
| Zumba....oh, don't forget your labor.....Oh, and it does matter....CNC is a not a cure-all.....the only thing CNC does is remove some of the human element.....the basic machine function or lack of function is still there.... |
#15
| [QUOTE=Mortgaged] I'm really not pleased with the whole gear head/quill arrangement as my machine has a particularly sloppy quill that easily moves >.015" during it's travel. Tramming is almost irrelevant and I have to keep the quill retracted and use the hand crank when I really need to maintain accuracy (flatness). QUOTE] My IH Mill has the same problems with quill travel. Moving the quill down 1" creates more than .020" error in the Y axis. I was trying to drill and bore some holes with less than .001" error perpendicular to the surface and discovered this problem with the quill. Basically the quill is unusable for any precision drilling or boring. Place a DTI in a collet in the quill and measure the run out up and down against a 1-2-3 or 2-4-6 block on the table then get ready to be sick. If you tram the mill head to the table then move the quill to another position the cutting tool is no longer parallel to the table. Don't bother using the quill for your Z axis in a cnc conversion if your machine has this problem. Would you guys check your machines to see if this is a common issue? I sincerely hope these are two isolated cases of this problem. How about someone who corrected this issue on their machine? BTW I have heard this is a problem with other brands of gear head mills besides the IH mill. Quill operations are important for the things I do. I purchased my IH mill specifically for manual operations. I have 2 CNC machines for the CNC stuff. Mike |
#16
Yeah, the labor is intensive and annoying. I certainly won't be getting another IH Mill. The CNC conversion gets rid of the crappy lead screws and handwheels... especially that dreadfull column leadscrew that has about a foot of backlash. Mike, unfortunately, I think the crappy quill mechansim is not isolated. The entire quill is best left LOCKED at all times. For procedures that require the quill, I think it's very difficult to beat a quality vertical mill. I recently purchased a Jet JTM-2 and it is a dream machine for me. It is so much nicer than the IH mill it's not even funny. By the way, what kind of a wrench have you been using to loosen the drawbar on the IH mill? I've been using a box end wrench wedged against the splines. |
#17
| So has anyone used the square lathemaster mill......... good bad?????????? i was really looking hard at the IH but all this bad has sorta made me change my mind this mill will only be used by hand no cnc so it needs to work well out of the box |
#18
I may repair my quill as I have access to a college machine shop with a precision rotary grinder. I may re-bore the mill head, install a sleeve and re-grind the quill. The lower gearbox seal is leaking and needs replacement anyway. Another option is to locate another head and adapt it to my column. I would rather repair the IH mill just for the satisfaction of doing it as I don't have room for a turret head mill anyway. Mike Last edited by MikeAber; 03-18-2006 at 10:39 AM. |
#20
| the quill problem got me thinking...what if all the mills are like this. so i checked my current round column one as well. what i noticed is that it pulls the quill as well when extended. however i also noticed that when i relieve the tension from the spring, then this problem goes away. i don't know if the IH one uses a spring to retract the quill but if it does this could be the source of the quill problem. |
#21
| [[B]QUOTE=Runner4404spd]the quill problem got me thinking...what if all the mills are like this. so i checked my current round column one as well. what i noticed is that it pulls the quill as well when extended. however i also noticed that when i relieve the tension from the spring, then this problem goes away. i don't know if the IH one uses a spring to retract the quill but if it does this could be the source of the quill problem.[/QUOTE] I believe you're right, I suspect all the gear head and belt driven bench top machines with this style quill will have this problem. The problem doesn't go away; it appears to go away. As soon as you place a side load on the quill, deflection will take place. This is only an issue with an unlocked quill during drilling or boring operations. There is too much clearance, allowing the quill to flop around. This issue can be minimized by tightening the quill lock until you feel the spindle dragging; however, this isn’t a cure for the sloppy fit. My Harbor Freight round column gear head mill had the same problem. I guess this is what happens when you compare these low-cost machines to turret head machines with precision-fit quills. In retrospect, I guess I’m expecting too much from a $1700 machine. I'm sorry guys! I guess it's time for me to accept the fact that my needs have now exceeded the capability of my machine. Even if I cure this problem, I'll probably find something else wrong. Maybe I'll become an Engineer. Mike Last edited by MikeAber; 03-18-2006 at 12:36 PM. |
#22
| It is a pretty huge problem if the quil does nto fit into the housing correctly. What you want is a lapped fit. The reality is that any of the methods described to "correct" the problem are only minor fix. What happens when you loosen things up is that you just allow the whole of the quil assembly to flop around in the housing. This kill the ability to get a good finish. Like wise if you clamp the quil you are likely only supporting it in one place. Then you end up with a spindle assembly pivioting around that clamp. A loose quil is just plain bad for general machining. What is worst is if you need to use that quil to bore getting a straight bore with a nice finish becomes next to impossible. I'm not sure if the manufactures are just sloppy here or if they are expecting people to make use of the Z travel. In the end I think things could be improved and at the same time made cheap if the quil motions where simply eliminated. Make use of the Z axis for all vertical movements instead. Hopefully this would allow for a stiff and square spindle retention. Interestingly if you search around a bit you will find examples of guys modifying their X3 and similar mills in the manner described above. That is the units have the spindle/quil assembly wither replaced or modified to be fixed and all vertical motion is handled by the Z ways. This is likely the only good solution that is cost effective and works really well with CNC conversions. Thanks Dave
#23
MikeAber |
#24
| Hello guys, I feel like rambling a bit and posting my view on this "z" axis quill quandry ! I hope ya don't mind and don't blow too many holes in my theory's here. Let me start on what is available here, round column, and square column. the round column has a straighter axis to the quil because it can be clamped tighter and still move along the axis, but you can't do much with the rotational weekness hense the square column. Now you have a dovetail slide and it is only so long and can only be so tight and the weekness in the thin section will flex to some degree allowing the head to tip away at the top of the dovetail. I watched this while setting up my IH mill gib on the "z" with a block of wood between table and quill and moving axis up and down against the block. the only way i can see of ridding this motion is going to a "box" slide. I have been considering doing a conversion on this and have a possible design in mind that may do the job, but it would be a vey long time from now before i could get to it, my idea would not entail removing the doves but adding to them and making the box portion wider and added to the column. then it would be required to make a new sadle to replace the dove and mate the head to the box. this would bring the heavy gear box true to slide and the quil would be true to the axis within whatever spec's exist from the manufacturing. If the quil bore was off then it would be a whole added process to true it ..... so ...... cost ! Isn't that why we are buying these machines in the first place ? if i had the money i'd buy the machine with the fewest week links, and then the weekest link in the equation would be "ME" ! ! My IH mill isn't on line yet but it will be in the near future and i know it has some extremely strong capabilities compared to many of the other machines that i used to dream about having. Mine is going to be full cnc per Aaron Moss's system, In fact, take a look at his website and the pic of the new V-3 on the top left of the home page ...... that machine is the one sitting in my shop. I will add that I have experienced that Aaron is tops and one honorable person to the highest degree and does in fact go beyond what he is required to do for his customers, Way beyond ! He is at the top of my list ! If ya want guaranteed top level support and a very capable machine, then look at his system more closely. The value is there. In closing here i'll add that yesterday, Aaron saved my ignorant butt from an expensive mistake on my part and didn't have to ! and I know it ! Now that is "TOPS" Have a nice day to you all
__________________ Don IH v-3 early model owner |
