Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Industrial Hobbies (Support forum)
Industrial Hobbies (Support forum) Discuss Industrial Hobbies Milling machines and get direct support here.
Old 01-12-2006, 08:50 PM
wildcat is on a distinguished road
Rigid tapping or tapping head
Is rigid tapping possible using the IH CNC kit or would it be better to get a tapping head? Most of the taps that I would be using are in the range #6 to 1/4.
Old 09-22-2006, 02:02 AM
triump is on a distinguished road
Bump...
I am courous about this as well. Is it posible with a VFD
Triump
Old 09-22-2006, 04:28 AM
Moderator
Halfnutz is on a distinguished road
I am no machinist, but I have several tapping heads and use them occasionally. They are great once you practice with them and get them set up for each part correctly. What I find is that alot of the tapping I have to do is easiest with a good screw gun, just because it is hard or impossible to get the part up on a machine some times, and the screw gun goes anywhere, especially for that range (under 1/4in.)
If your doing a lot of production on parts though I think a tapping head would be well worth the money, you will save in broken taps and ruined holes in the long run on stuff that size, but maybe there is a way to ridgid tap I havent learned yet.... The VFD might be the trick...
Halfnutz
Old 09-22-2006, 04:54 AM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
get a piece of scrap and an old tap and try it at a relatively low speed , best way to find out ,
Old 09-22-2006, 10:54 AM
TPPJR is on a distinguished road
I don't think that rigid tapping is possible unless you have a servo spindle.
Thomas
Old 09-23-2006, 09:26 AM
Cruiser is on a distinguished road
Without a servo spindle or an encoder attached to spindle for tach output rigid tapping is impossible in the IH mill, I have been pondering ways of puting one on my system but nothing yet. Get the tapping head and one for me too while your at it ! hahaha
Don
IH v-3 early model owner
Old 09-24-2006, 02:08 AM
BobWarfield's Avatar
BobWarfield is on a distinguished road
To rigid tap you essentially need to synchronize the spindle to the Z-Axis just as you would synchronize the leadscrew on a lathe to the spindle. Mach 3 doesn't support it at this time, though Art does get asked about it a lot. I'd go for a tapping head.
BTW, I understand the slick way to go for small production shops involves some sort of an articulated arm with a motorized tapping head attached. I've seen it somewhere on Practical Machinist, but don't have a link handy at the moment. You can Google "articulated tapping" and see the devices I'm describing.
Another possibility is to power tap. This is a manual operation. You need to unlock the quill and basically let the tap drag itself down pulling as it cuts threads. Some details here:
http://www.cnczone.com/cg...1;t=022668;p=0
or
Tapping heads
also discusses power tapping.
Best,
Best
Old 09-24-2006, 01:08 PM
handlewanker is on a distinguished road
Hi, If you've ever done any thread cutting in a lathe using one of those sliding die holders then you can also use this method for tapping, only now the end that normally holds the dies has a hole for the tap and two grub screws for the drive.
To use just get the tap into the job with some down feed and then let it pull down by itself. If the tap is marked with a turn of masking tape then you just reverse out when ready.
Works OK for small amounts of tapping, but it pays to get the proper tapping head if you want to do it regularly.
If it's going to be used with CNC, then the holder is spring loaded and the spindle remains up and only rotates to drive the tap.
Ian.
