Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Industrial Hobbies (Support forum)
Industrial Hobbies (Support forum) Discuss Industrial Hobbies Milling machines and get direct support here.
Old 01-04-2006, 12:36 AM
wildcat is on a distinguished road
Zeroing the dials?
Is there a way to zero the dials on the Industrial Hobbies mill? I fiddled with the dials tonight and did not appear be able to be zeroed. Is this correct or perhaps mine are rusted stuck?
Old 01-04-2006, 07:51 PM
Oops - brainfart - figured it out - was looking for a thumbscrew and thought a different part would turn than what actually did. Needed to grab the dial and the knurled bit and turn the dial. While pretty tight it did turn and was able to zero out.
Old 11-17-2006, 06:53 PM
FWIW - Here is what I did make zeroing the dials reasonable. The dial actually turns on an internal shaft with a small piece of spring metal creating resistance. Probably fine in most cases but mine turned so hard it was impossible to not loose zero thou zeroing the dial. Just had to disassemble, drill, and tap for the thumb screw.
