I know what you mean on which path to take. I think I'm going to try Arizona's method first, then I can always come back and cut the web out. Good luck.
Ron
I am having a bit of an internal struggle trying to decide if I should cut out the cross brace on the Z axis column.
I understand that IH cuts it out on the turn key CNC mill but I am wondering why after all this time have they not simply modified the casting?
Has anyone ever noticed a difference in column strenght after it was cut out?
Thank you for your help.
Kelly
Web: http://www.cnceffects.com
Ron
I cut the tie out of my column about a year ago after running the cnc conversion 6 months or so. It needed to go so I could use R8 collets and cut parts on the table, not in my vise. I've since pretty much stopped using R8 collets the past 6 months or more so that tie may have been able to be left in place. Don't know for sure though because I use a ER collet holder that's not that long. And I still cut parts on the table (on a sac plate or fixture).
Honestly, I can't tell any difference either way. I'd think that if all you run are setscrew style tool holders and Jacobs chucks, it could probable stay in place. Especially if you always cut in the vise. Or, extend the quill a bit when the need arises.
Bob
IH has had some mod's done to the castings, But, they are all delivered as manual machines and require the aditional mod's for CNC conversions.
One of the most noteriety mod's they had done was to stiffen the dove tail cut are of the column on the inside, it adds a lot of rigidity material to the inside or thinnest area of the collumn to help keep it from distorting from the gib adjustment tensions. If you haven't gathered, it is difficult to say in words !
Don
IH v-3 early model owner
Arvid, I'll see if I can find the info regarding the "L bracket". Hopefully Arizonavideo will see your post and lead us to the link.
When I did my Z mount I re surfaced the mounting pad and moved the bolt holes up on the slide by about 1.5" adding two two M10 bolts instead of the one M12.
You need to look closely at where the bolts are as you don.t have a lot of extra room with the mounting ring and webbing around. The metal was real thick with one bolt going through at least a 1.5" of cast iron.
I took a few pictures of how close I can get to the table now.
The quill is all the way up and the block is a 123 and the head is all the way down so it looks like I can get to about 2.5" of the table.
For me that is just fine as I almost always have the work on at least a 1"block and extending the quill 2" is no big deal.
I would like to add that the castings I have seen lately do look a bit different than my IH (2 year old). The mounting pad on my Z was a oval shape and the last one I saw here was nice and square. The column cross brace on mine is slightly curved where the picture above it is really square looking.
I was thinking of filling up the bottom 12"or 14"of my column with cement and 4 thread rods to go into the base. This might transfer the shock loads a bit better and their is nothing in the way. Cement should stick good to all that flashing.
If you look at this guys build the Z slide is a lot different than mine. The mounting pad sticks up and the rest of the area is much lower than mine was.
He will lose some Z at the table unless he cuts out the cross brace which may be OK I don't know.
http://www.cnczone.com/forums/attach...8&d=1324620403
On mine the 3 head mounting bolts also were standard 6 sides bolts with no shoulder that made small cracks in the casting. I had to replace them with shoulder bolts that you have to mill down a bit to make them fit. Much better bolts, the stock ones are butter.
Here is what I did last night...
Kelly's Machine Tool Warehouse - MD001
Much like Arizona's mod.
Kelly
I would think that the angle iron will flex some.
Perhaps a nice big block of something.
