It probably would not take much of a press to take it apart. Using a press (even an arbor press for light duty work) is better than beating on it with a hammer.
If the spindle has a hole right through, enough to pass a length of threaded rod through, you might be able to pull it out with an imaginative pile of spacers and rings and a piece of pipe.
LinkBack URL
About LinkBacks
