Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Industrial Hobbies (Support forum)
Industrial Hobbies (Support forum) Discuss Industrial Hobbies Milling machines and get direct support here.
Old 08-13-2005, 12:46 PM
Roy Norris is on a distinguished road
Swing on the IH mill?
Does anyone know the distance from the center of the spindle to the vertical column, ie, the swing, on the IH mill? I am trying to figure out how large a rotary table can be mounted on the mill.
Roy
Old 08-15-2005, 11:24 AM
Randall is on a distinguished road
Roy
If you like I'll measure it tonight. Maybe somebody else will chime in.
Randy
Old 08-17-2005, 04:40 PM
mcarvey is on a distinguished road
I measured 9.75" from the center of the spindle to the front edge of the bellows on the column, so you should be able to fit a pretty good sized rotary table on the table.
-Matt
Old 08-17-2005, 06:45 PM
Many thanks! Yes, that is a lot of room. More than I immagined! I'll be able to mount a 10" table with room to spare.
Thanksvery much --Roy
Old 08-17-2005, 07:57 PM
*Registered User*
ChrisJ is on a distinguished road
I have an 8" Phase II table. I got to tell you it is heavy enough. I wouldn't want any bigger just for the man handling part of it. Make sure you need/want a 10" table.
Chris
Old 08-18-2005, 01:12 AM
Yes, the 10" table is a "gut buster" but I need the 10" diameter for cutting some reall big brass gears. I just bought an engine crane from Grizly to help move stuff around the shop. (Like getting the IHmill onto its table when it arrives!)
Roy
