Results 1 to 6 of 6
Thread: CNC X Limits
    Registered saabman's Avatar
    Jan 2010
    CNC X Limits
    The IH X limiter works by ulitizing the manual X T-stops to trip the optical limiters. My question is in the CNC environment do you set the stops once (at max travel) and leave them there?
    Chris
    Jan 2010
    The reason I ask about the limit is I have a 32 inch glass DRO scale that I plan to mount on the table. I will make a compound mount for the scale, it will afix it to the table and provide the trigger ear to trip the limit switch. The limit switch will be stacked on top of the read head for the DRO.
    Chris
    Feb 2006
    Set once to extrema and leave alone.
    The only exception is with the Z.
    My Z has been modified and only limits the top of travel as it is not going to stop a tool from hitting table or.
    Don
    IH v-3 early model owner
    Jan 2010
    Thanks Don, that was what I was hoping
    Jun 2005
    in your case i would mount them to protect the scale. no reason to damage your 32 in scale in case of run away.
    Jan 2010
    The idea is to make a compound mount for the scale. At 32 inches it will extend just beyond the travel limit of the table. The limit tabs will sit on top of the scale and point inward towards the saddle. A common set of bolts will anchor the scale and the limit tabs.
    1. IH limits....
      By pete from TN in forum Industrial Hobbies (Support forum)
      Last Post: 09-01-2009, 12:34 AM
    2. Home Limits
      By kolias in forum DIY CNC Router Table Machines
      Last Post: 06-05-2009, 10:12 AM
    3. Out of limits
      By monte55 in forum Machines running Mach Software
      Last Post: 11-04-2006, 10:28 PM
    4. we all need limits!
      By senor J. in forum General Electronics Discussion
      Last Post: 08-24-2006, 01:06 AM
    5. limits
      By jc286006 in forum TurboCNC
      Last Post: 09-08-2005, 06:05 PM
