Results 1 to 4 of 4
Thread: Lead screw nuts and end supports
    Mar 2010
    Hi everyone. New to the forum. Got my IH mill a few weeks ago... Very cool. I am in the process of doing a cnc conversion on it. I cant quiet afford the cost of the factory unit so im doing it on my own. I was wondering if anyone had drawings they have made of the lead screw nuts for X Y Z and the lead screw end supports. I would like to build them before i tear this mill down... because i need the maching to build some of the parts.
    dj
    Mar 2006
    I am doing the same thing
    if you go to rockford ballscrews website you will see differnt options on mounting them
    I plan on using a modified version of one of them
    if this does not help I can take measurements for you
    I don't have drawings yet
    Jan 2006
    I would hope that anybody that has bought a turnkey cnc mill or kit from IH will not post that info for others to copy.
    Mar 2010
    Nut mount
    Thanks... I really just need the drawings and measurements on the leadscrew nut mounts and the end plate. This way i can design my own supports and build them on my cnc's at work. I plan on using a double ball nut on my lead screw. one on each side of the nut mount. I can put set screw into the threaded area and make my own preload. I can also install an oiler right into the mount assembly to keep it running smooth. I just really hesitate to pull this mill apart till i have all the conversion parts put together.
    dj
  1. lead screw and nuts
    By rfkhan28 in forum DIY CNC Router Table Machines
    Last Post: 12-21-2008, 07:52 PM
  2. Tapped Nylon Spacers as Lead Screw Nuts
    By cely in forum Linear and Rotary Motion
    Last Post: 11-10-2008, 04:14 PM
  3. lead screw nuts wanted
    By Bill Harrison in forum General Metalwork Discussion
    Last Post: 03-04-2008, 01:37 AM
  4. WTB: Lead screw nuts for Bridgeport Style MSC (Taiwan) knee mill for X and Y
    By modernprecision in forum Want To Buy...Need help!
    Last Post: 03-03-2008, 02:02 PM
  5. Lead Screw end supports
    By Hack in forum DIY CNC Router Table Machines
    Last Post: 10-11-2005, 06:46 PM
