Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > I.C. Engines
I.C. Engines Discuss home made Internal Combustion engines here!
Old 03-08-2009, 02:27 PM
JpBinc is on a distinguished road
COnnecting rod bearing
Hello everyone
I have a question about con rod bearings. Can you use a ball bearing on the large end or is heat a factor. I do not think that you could use one on the small side (piston pin) because of heat. Has anyone ever done this. 12cc to 15cc 1" bore 1" stroke.
Old 03-08-2009, 05:49 PM
timmydabull is on a distinguished road
i dont see why you could not,i know of very large connecting rods using roller or ball bearing configurations.
do a search on 2 piece bearings and you will find more info on this subject
2007 Haas TMP-1 Microscribe MX-5 Mastercam X4 Mill Level 3 Surfaces,Solids Seagate 2 tb hard drive AMD 64x2 8gig ram windows ultimate 7 64bit Geoforce 8800 GTX
Old 03-08-2009, 06:50 PM
IKO makes caged needle roller connecting rod bearings for both the big end and small end.
Big end bearing bore 8-32 mm bearing od 12-42mm. Small end bearing bore 9-18 mm bearing od 12-23 mm. That's how they're listed in the catalog.
Dick Z
DZASTR
Old 03-08-2009, 08:12 PM
stevehuckss396's Avatar
stevehuckss396 is on a distinguished road
Originally Posted by JpBinc View Post
Hello everyone
I tried it on my straight 8 project. Bore is .875 and the stroke is 1.0625. Have not started it yet. You can do it if you have the patiance to make, press and align all the sections. 17 pieces, 9 main bearings and 8 rod bearings. It is expensive and hard to get straight. If i had to do it again, it would be one peice with bronze shell bearings. At least now i can say "I did it"
Cheers!
Steve
ID:	77157   Click image for larger version
ID:	77158   Click image for larger version
Old 03-09-2009, 07:54 AM
BillTodd is on a distinguished road
Cheers!
Steve
Knowing the effort it takes to align just one pressed together crank, I take my hat off to you. Amazing work
Bill
Old 03-09-2009, 08:43 PM
It will never happen again!!
Old 03-11-2009, 05:19 AM
dmh13433 is on a distinguished road
Here is a picture on the back of issue no. 30 of Strictly I.C.
I never found anywhere where they said how Lew Blackmore did this.
It is really too bad Mr. Blackmore died before he could share this engine with everyone. I remember reading the letters to editor, it was all finished except getting the magnetos working.
Old 03-11-2009, 02:09 PM
WOW
Thanks for all the comments. Steve your a wild man.. Impressive indeed. I wonder what the real design pros and cons are. Things like longevity, friction, etc..
Old 03-11-2009, 06:21 PM
My guess (and that's all it is) is he made the crank small enough to fit through the large main bearings, with each bearing seat spherical (or spherical enough) to allow the bearing to pass around it.
Bill
connecting to 3d printer clint Computers and Networking 15 07-25-2011 03:49 PM
Connecting rod ACME I.C. Engines 18 08-11-2007 12:09 PM
Connecting Gantry droddis DIY-CNC Router Table Machines 0 07-06-2007 06:06 PM
Tapered roller bearing vs. angular contact bearing boyvox Linear and Rotary Motion 12 01-25-2007 02:49 PM
connecting KrashKing405 Open Source Controller Boards 18 07-26-2006 05:30 PM
