| I.C. Engines Discuss home made Internal Combustion engines here! |
I was trying to come up with an idea how to improve bearings in a fractional HP low RPM engine by using ball bearings what do you think ? I think the side crank design is the only possibile way to easily replace it's bearing when the bearing is a ball bearing. The two arrows indicate where the two halves of the case bolt together. Last edited by Andy-7300; 07-09-2008 at 09:54 PM. |
| See page 20 of http://manuals.hobbico.com/osm/fl-70-manual.pdf for another way to achieve the same thing.
__________________ Red to red and black to black, or it's ashes to ashes and dust to dust. |
| If this as yet untested design caught on I guess it would be the first time an IC side-crank engine went from being made for reasons of ease of manufacture as in the case of model airplane engines to reliability and serviceability. If you like the idea of a side crank then the only main difference between the two designs (my drawing and the OS FL-70) is my incorporation of a internal flywheel ,the reason I did that is for reasons more of what I don't know than what I do know although I know it reduces stress on the main bearings, reduces vibration and is probably more compact. Also this engine is intended for stationary use applications or where weight isn't a factor and to run at 2,000 - 4,000 RPM. Last edited by Andy-7300; 07-12-2008 at 04:27 PM. |
| Making Large "Turner's Cubes" on an Engine Lathe | widgitmaster | General Metalwork Discussion | 100 | 02-26-2012 05:23 PM |
| "Fixing" bent engine valve? | mmmjboner | Bending, Forging,Extrusion... | 18 | 07-16-2007 03:40 PM |
| Book "Elmer's engine" | Hans-Jürgen | Steam Engines | 3 | 07-23-2006 01:33 AM |
| "M" Side Crank.Built to run. | tool_man | Steam Engines | 3 | 06-06-2006 11:23 PM |
| V18 "Internal Error" | mikesos1 | BobCad-Cam | 2 | 02-06-2005 11:28 AM |
