Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > I.C. Engines
I.C. Engines Discuss home made Internal Combustion engines here!
Old 05-03-2008, 08:01 PM
elmerfud is on a distinguished road
Cosworth DF series motor.
Hey guys, I have a cool idea.
When you start a source file project, ie 'reverse engineering flowerpots' we could post the source files for others to use. I am not asking people to give away hard earned cad data, just reference drawings like front, side, top, rear veiwed photograghs. (please modify them enough so as not to breach copyright).
Maybe I could start with some Cosworth dfv stuff?
Hope this catches on!
ID:	58946   Click image for larger version
ID:	58947   Click image for larger version
Old 05-03-2008, 08:18 PM
Lamborghini V12
Here's some lamborghini F1 V12 info.
ID:	58950   Click image for larger version
ID:	58951   Click image for larger version
File Type: txt Lamborghini_F1.txt‎ (542 Bytes, 103 views)
Old 05-03-2008, 08:27 PM
ilmor V10 1998
Heres some ilmor V10 stuff.
File Type: txt ilmorV10_98.txt‎ (557 Bytes, 109 views)
Old 05-03-2008, 08:50 PM
F1 v6 turbo
I really have no friends so I keep replying to my own posts, sad huh?
1988 honda v6 turbo, I lost the text but its easy to find. There was an SAE paper on this motor with rich, detailed information.
ID:	58956   Click image for larger version
Old 05-03-2008, 08:59 PM
Ripped off!
I am sorry, I uploaded large GIF formats files but it would appear the moderator has resized and reformatted to JPEG resulting in detail loss.
Each file was kept under 500kb as requested but the result has been less than I had hoped. Happy cad drafting kids.
Old 01-30-2009, 01:53 PM
bfloresf1 is on a distinguished road
Hey I am trying to find some drawing for the Aurora Engine or any F1 engine to cad up for my self and later make a 3d model in SolidWorks. Where do you think i can find some info?
I am realy impresed with your drawings.
Ben
Old 01-30-2009, 10:37 PM
dynosor's Avatar
dynosor is on a distinguished road
http://www.replicaengines.com/products.html
http://carlsonengineimports.net/products/aurora.shtml
Maybe not...
Red to red and black to black, or it's ashes to ashes and dust to dust.
Old 01-31-2009, 03:47 AM
Adaware is on a distinguished road
Remarkable to see how tall the cylinder heads are on the cosworth and other racing type engines.
Old 01-31-2009, 11:47 AM
dynosor's Avatar
That is because the inlet and exhaust ducts are almost as wide as the pistons to allow flow at high RPM...
I am sure the ports and runners are configured in wide arcs to reduce flow losses - a passenger car might have a kink in the runner where it meets the valve to reduce the height and therefore cost of material in the cylinderhead.
Old 01-31-2009, 11:49 AM
dynosor's Avatar
As 8.58 Mbyte ZIP files are allowed for things like CAD, why not zip your pictures into one file?
  #11   Ban this user!
Old 01-31-2009, 04:26 PM
Gee, I have not looked at this post for at least a year.
Hello BFLORESF1, your going to like what I will tell you.
The Aurora motor is basically a u.s.a production v8 with a massive destroke, trumpets,dry sump, big ports and big cams.
Being a production v8, there should tonnes of literature on this motor.
Failing that, buy a gasket set for this motor and draw up the patterns to make you own blueprints.
Or find a self serve car graveyard and spend a day there with your vernier caliper, tape measure and steel rule carefully measuring and sketching notes to later put into cad.
I am confident you should be able to build a very dimensionally close scale replica.
Please post some photos of your sketches later down the track pal. (low res)
  #12   Ban this user!
Old 01-31-2009, 06:23 PM
Ref: Aurora Nearly the same as it's parent, Cadillac Northstar.
Dick Z
DZASTR
phase ultract 2 ac servo motor - good for series II Bridgeport conversion? cezzo Servo Motors and Drives 0 08-05-2007 10:00 PM
Good source for motor replacements of Series I stepper motors? Mr. Technical Bridgeport and Hardinge Mills 1 07-27-2007 10:16 AM
dc series universal motor jed102 Servo Motors and Drives 6 05-02-2007 09:09 PM
Identifying Bridgeport Series 2 Interact 4 Spindle Motor UKRobotics Bridgeport and Hardinge Mills 2 05-26-2006 06:55 AM
Series 1 Boss 6, Main Motor DaveinUK Bridgeport and Hardinge Mills 5 12-14-2005 03:02 AM
