Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > I.C. Engines
I.C. Engines Discuss home made Internal Combustion engines here!
Old 03-17-2008, 12:29 AM
Hiredgun is on a distinguished road
rod and main bearings
does anyone know of a supplier that makes split sleeve roller bearings in sizes like 3/8 and 1/2 inch id.
#2-- what do most people use to make split sleeve bearings out of.
any other comments along these lines would be appreciated.
Old 03-17-2008, 08:22 AM
chipduster is on a distinguished road
thomson shafting/bearings:
http://www.danahermotion.com/website...ment/ALMTG.pdf
they offer recirculating ball type and also nylon ones, mounted pillow or bushing. depending on your application the nylon ones are very affordable, only somewhat less so are the ball type in the size you mention.
i've made my own... but i would advise against going there unless you feeling like playing around.
Old 03-17-2008, 08:41 AM
AS9100 is on a distinguished road
I believe Thompson bearing or Nippon bearing may have what you want.
Motion industries is where i would call first.
Old 05-04-2008, 12:46 AM
elmerfud is on a distinguished road
I know where your heading and I have the same concerns too.
We all might be able to build a motor that fires, but one that lasts for 100's of hours is a different story altogether.
Your Main Page Is Down ! CheekieMonkies Forum Questions or Problems 10 08-19-2007 05:26 PM
main haas board daleman Haas Mills 4 03-16-2007 06:58 PM
sizing main disconnect 69owb General Electronics Discussion 1 04-01-2006 04:00 PM
main page pictures CNCadmin CNCzone Club House 19 02-10-2004 06:16 PM
No Icons on main page ger21 Forum Questions or Problems 1 08-11-2003 09:16 AM
