| I.C. Engines Discuss home made Internal Combustion engines here! |
| Is that a drawing of the Ferrari 3.6L V8? If it is, then I am very impressed and will not ask how or where you got that pic Do you have any other views or specific dimensions like bore, stroke, compression etc? I would be interested in this project once I finish drawing up a model turbine in solidworks (i've attached a pic) |
| Yes it is, I only have a front view dxf with a head cutaway. But im sure its factory source drawn, the bore to stroke is 85x79 but i dont have cad for the internals below the head. It came out of a owners manual pdf file. (neat trick) Your turbine looks nicely surface modeled. Do many people turn old turbos into turboshaft successfully? Id like to do that one day, a turboprop rc plane would be to die for. Are you stamping the blade profile or machining it? Stamping would reduce build time massively and make blades cheap to replace. |
| I'm not sure how successful turbo to turbo shaft conversions are because they are very rare and rarely documented. This turbine is being modeled from a set of plans as I have no previous experience with turbines and wanted a good working final product. The company has all of the parts available for purchase if you want, but I plan on machining everything but the compressor wheel which is from a Garrett turbo. I just recently purchased a 1:150 harmonic drive and I will make my 4th axis from this to finish this turbine project. I also found the manual with the drawing and a picture of the camshaft with pistons and the valve side of the heads. I'll post them soon. |
| Sounds like a turbine would be the go. I spent 5 years reverse engineering a ferrari f1 v10 from cad images and photos of dismantled engine parts, i now have detailed plans. The work involves 7 highly detailed casting patterns, 40 valves, stems, finger followers, 20 straight cut gears, 10 connecting rods, an incredibly detailed crankshaft, 4 camshafts to name just a few of the parts involved, totalling maybe 1000 parts. I have not started, its to supermassive project to fathom now i have studied its intricacies. A turbine looks far easier and could yield a far greater potential from loss of friction alone. But still i want this V10, so slowly over the years i shall make the patterns and make bits and pieces, but it is no practical project for any short to medium term results. |
| Good Start Elmer, i would rather die to build one. But as you say its not practical to make 1000 parts in a short or medium term single handedly. i think if more members can join to build i think it is achiveable in a short span. Say ten people making 100 parts and sharing. Well i am interesed and will be the first volunter. Inviting all enthusiats to join. |
| What are you planing on building it out of? Machine down from bar stock, or cast the block and heads? Would the cams be exact match's, 4 of a kind? Or would the lobes be placed in different positions of timing? How much of a scale down is it from original size? Is class in secession?
__________________ Make sure you clean my wrench before you put it back into my toolbox. |
| Hey elmer, Did you make a cad drawing of the F1 engine? If so, can you post some pics? Just out of curiosity, you mentioned that you had cad drawings and pictures of parts of the engine. Where did you manage to find this? |
#10
| The V8 plans come from a pdf file from ferrari, a program called 'adobe illustrator' extracts the 'scalable vector graphics' into dwg or dxf. Often it is original factory cad the artists used. I have not exhausted all avenues of possible cad data to be obtained from this method. If i have the band width i will try and find some motorcycle engines from factory manuals. I will make a 1/4 scale v10 motor but simplify the innards to be a possiblity. I started designing a 3/4 scale design using CBR900 pistons and 1300cc for hillclimb. But then after much thought a destroked Mazda Kf v6 or a hyabusu engine is much smarter. Realisticly, I will try and make billet v10 about 160mm long, i will keep you posted. I posted this forum because 'MotoGp single cylinder' thread by JLcortes had died of and was wondering how many like minded people were out there. (was a good thread) |
#11
| Well, this is the v10 so far. Figuring out spark plugs will be fun as will oil pressurising the crank shaft. I started out with a reverse design cad of the ferrari v10 but have decided to apply the design to a 72 degree renault package as i am currently 3d modelling a R24 f1. (engine balance also) I have modelled a F2003ga in surfaces (phew took ages), but i am a alonso fan, schumacher sucks. Has anyone had success 'white metaling' conrods at home? Has anyone succeeded holding oil pressure in scale motors? I am worried it will run for 10 minutes then weld itself frozen. Does anyone have a blog for rejetting walbro carbys? Has anyone succesfully figured out a self contained ignition in scale without large boxes of hidden stuff? Would appreciate any help. |
#12
Just scale the oiling system down to the size you need it to be???? I'm guessing. Make a magneto for the ignition. If you know your computer control systems, you can probly control the entire needs with a small flash drive???? Again i'm guessing.
| Motorcycle Mirror Mounts | MFP-2241 | Employment Opportunity | 14 | 10-14-2007 07:20 PM |
| where to source motorcycle blank hubs? | SRT Mike | General Metalwork Discussion | 3 | 09-17-2006 04:12 AM |
| Motorcycle rims | RayDOsity | General Metal Working Machines | 36 | 04-21-2004 03:57 PM |
