Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > I.C. Engines
I.C. Engines Discuss home made Internal Combustion engines here!
Old 07-24-2007, 02:51 AM
stem fan1 is on a distinguished road
looking for four stroke plans
looking for any push rod or sohc engine plans
ignore the spelling mistake
Old 07-24-2007, 10:48 AM
Speedygonzales is on a distinguished road
im not sure what those are yet, but have you seen this.
http://home.comcast.net/~webster_engines/
Old 07-25-2007, 05:06 AM
yeah looking for sumpthing a bit more up scale
Old 07-25-2007, 02:33 PM
Mcgyver is on a distinguished road
stem, have you seen Eric Whittles air cooled V8? very nice engine, fits in your hand and representative of a wwI aeroengine. was printed as a series in ME a few years ago. if you go the chaski home machinist site and check out the IC section, there is a link posted to some scans.
there are many many successful designs out there that have published over the years. subscribe some of the mags, join model engineer forums or just surf, for sure see something that catches your eye
Old 07-30-2007, 08:17 AM
Mago is on a distinguished road
Stem, Look in Model Engineer from 13 April 2006. Plans and construction notes have been serialised in alternate issues.
I have made it and it runs well. No gears to make and will run as Glow plug or spark ignition.
Would post a pic if I knew how.
Mago
Old 07-30-2007, 01:07 PM
Mago, go to putfile.com and make an acount, load the pic up on there then put the html (it should have all the code to post it already)
if not send the pic to me and i can put it up for you?
imfishguy@hotmail.com
Old 07-30-2007, 02:01 PM
skmetal7 is on a distinguished road
all u have to do is go to the "manage attachments" button on the lower part of the page when u press "post reply", find your pic on your harddrive and click "uplaod"
Old 07-30-2007, 09:19 PM
The model is NE15S designed by "Nemett" and serialised in Model Engineer.
Plans may by bought directly from the designer.
The model is about 15cc capacity with a 25mm bore. it is wet sumped and splash lubrication means no oil pump. the single cam drive is by toothed belt so no gears to cut. Cams are cut on the bench mill using a rotary table. A pair made together, then separated, case hardened and Loctited to the cam shaft. Bearings are roller or ball. You'll love this, dimensions in metric.
Mago
hope it worked
i put the text up Mago.
looks great and i love it!
two stroke engine PoWaKiD42 I.C. Engines 50 10-03-2007 12:59 AM
anybody with 2 stroke plans stem fan1 I.C. Engines 4 09-28-2007 08:08 AM
2 stroke porting Tom Brown I.C. Engines 8 09-05-2006 02:48 PM
Hypothetical 2 stroke v-8 jrc347 I.C. Engines 25 06-15-2006 07:16 PM
4 stroke engine: castings & plans motordude I.C. Engines 1 03-02-2004 10:08 AM
