| I.C. Engines Discuss home made Internal Combustion engines here! |
How simple is it to make the carbys found on the mini ic engines? i'm not out to make one for a long while yet, just curious to see how simple they are. rhino
__________________ On the other hand, You have different fingers. |
| Wondering the same thing, I was going to cheat for starters and use a carby of a 4 stroke Whipper snipper. I am thinking EFI might be easier than carbies, for smaller motors, just don't know how to get injectors that small... Russell. |
| This has more to do with your skill level and the equipment available, than the carb itself. Some are more complex with throttle, idle ,peak and mixture settings. Basic carbs are not much more than a needle valve and a spray bar in the venturi tube, which may or may not have a venturi shape. Start with a basic engine that has a throttle type of carb and follow the print. Whatever you may be comfortable with. Otherwise, find a carb you like and duplicate it. Then try it out on the engine the original carb came on. DC
__________________ Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade. |
Hi rihno Here is plans for the carburettor for the Seal engine,it should give you an idea of of how a simple carb works. Ivy McNeil
__________________ I did not fail,I found 10,000 ways that dont work |
| If anybody needs them I have various plans which I downloaded from some Yahoo groups including, but not limited to: Sealion 30cc OHC Seal 15cc Amsbury V8 120cc Whippet 10cc(?) Wallaby Mastiff 24cc opposed 4 Whittle V8 10.6cc glow ignition Alpha model diesel engine Some random glow ignition 2 stroke and more This is related though as each engine has a carburetor design |
| I would definately like a copy of those plans, some (most) are probably a little out of my league but I would still be interested in a look. You can PM me if you want to work out the details...or if Rhino doesn't mind link or post them here. Cheers. Russell. |
#10
| I dont mind at all! post away. it'll probably give me a greater understanding of the construction of these things(especially the V8). rhino
#12
| Here is what I have found over the years. These used to be posted somewhere on the web, but I can no longer find the link that I found them on. Thanks to Jones for making them available here. he had a couple new ones I have not come across. Alpha Diesel Amsbury 120cc V8 From Scratch Hawk 40 Mastiff Seal Sealion Wallaby Whittle V8 Wyvern
__________________ Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade. Last edited by One of Many; 05-02-2007 at 12:49 PM. |
| Plate model | corrie | Rhino 3D | 16 | 08-03-2007 05:02 PM |
| Model or Scan? | robinsoncr | Rhino 3D | 8 | 02-27-2007 10:54 AM |
| parting off a 3d model... | jasonwinters | SprutCAM | 25 | 09-30-2006 03:42 PM |
| need help making a model | replicapro | Rhino 3D | 3 | 06-05-2006 12:57 AM |
| Looking for someone to do 3-d model | seansear | Employment Opportunity | 5 | 08-13-2004 04:39 PM |
