| I.C. Engines Discuss home made Internal Combustion engines here! |
Don't need it for anything, just thought it would be fun and cool... this one looks interesting: Webster NGEZ I'm looking for something like this... not looking into anything high tech, just something simple to start off with... the basic. I wouldn't mind building this, just want to see what else is out there. I don't mind paying reasonably for plans either Thanks and Cheers Goran |
| There is a book by "The motor boys" that is supposed to have plans for a bunch of small engines very much like the one you have posted. Follow this link and at the top left there is a link to the boys. The book is 20 bucks and has plans for 10 or more engines http://modelenginenews.org/ |
| I am also looking for a beginners engine, and I think the problem with the one you posted as well as most of the Motor Boys engines is that they are Diesels. They require a high compression ratio, so your piston needs to seal very well to the cylinder. Unless you can source a ready-made piston/liner combo, this might be hard to achieve. |
imo the trick to best of class piston/cylinder fits is to learn how to make and use laps. unlike honing, a lap used properly will correct errors in the bore. you end up with a perfectly parallel round bore that you can take up to a mirror finish. with this homemade equipment you can produce fits and finishes with any old lathe that'll look and perform like you've a shop full of the best grinding equipment. if you are interested in making engines, here's some notes and pics i did on how to lap bores. for the smaller bore of the aero engines, the barrel lap is most appropriate imo http://bbs.homeshopmachinist.net/sho...highlight=laps |
Good point! Try this one. Uses cox cylinders and minimal parts. Only bad part is the tap is a bit pricy. But you could always get around that by cutting the threads on the lathe. I have the plans for the first and bought the kit for the second. Plan on building both after i finish the little Bugatti. http://www.jamesengine.com/index_files/Page486.htm or if you have a few more bucks. http://www.jamesengine.com/index_files/Page662.htm Steve http://forum.bugattibuilder.com/phot...s.php?album=27 |
| If you want to see some advanced hobby engine, built by a "hobby pro", with parts partly cnc-machined you can look at this guy: http://fly.to/orkenrud Just if you ever doubt that the sky is the limit... All have been up and running exempt for the Merlin, not yet... /Jan (I'm far behind and green in envy and I haven't even bult a single cylinder two stroke yet) |
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
| R/C Foam airplane plans in dxf or dwg | corydoras | Hobby Discussion | 6 | 10-20-2008 05:35 PM |
| Airplane creation | Atomik Rooster | Solidworks | 14 | 12-27-2006 01:30 PM |
| I need some molds made for an eps airplane | Ryan Archer | Moldmaking | 5 | 09-02-2006 10:58 AM |
| OLD Airplane servos | cadfish | General Electronics Discussion | 1 | 08-25-2005 03:58 AM |
| Anyone build a 4-stroke I.C engine? | CNCadmin | I.C. Engines | 6 | 03-14-2004 03:55 PM |
