Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > I.C. Engines
I.C. Engines Discuss home made Internal Combustion engines here!
  #61   Ban this user!
Old 04-02-2011, 01:20 PM
Swede's Avatar
Swede is on a distinguished road
That is awesome... It's got to be tough to get nice, smooth running at such an RPM!
Great job!
  #62   Ban this user!
Old 04-03-2011, 12:55 AM
bluejets is on a distinguished road
Just posted a couple of videos on youtube of the 4 cylinder boat engine.
One is much clearer than the other.
I found out that it was better to remove power from the glow plugs after the engine had started and you will hear a big difference in the top end speed.
[FONT=Times New Roman]http://www.youtube.com/watch?v=hXdLRe_MWI8[/FON"]400 Bad Request[/FON"]400 Bad Request
When it opens there is a section "2 videos" to see the second one
  #63   Ban this user!
Old 04-03-2011, 07:28 AM
stevehuckss396's Avatar
stevehuckss396 is on a distinguished road
Great project. I have been looking for something to put a 1/5th scale V8 into. Maybe I should look at boat plans.
  #64   Ban this user!
Old 04-03-2011, 06:49 PM
boat and engine
Boat plan I used was from a full scale set I found on the internet. Downloaded in A4 format and then kept blowing them up a bit at a time until I came to the size I needed.
RunaboutsInboard riviera
  #65   Ban this user!
Old 09-19-2011, 11:32 PM
skmetal7 is on a distinguished road
own design, 3 cylinder, sleeve valve. I think my carb is wayyyyyy too big though, keep flooding it. will try a smaller carb, not sure what size though.... maybe look for a single cylinder .35Cu In engine and get a carb similar in size.
.746" bore, .800" stroke (.35 Cu In per cylinder), 10-40 spark plugs. electronic ignition.
ID:	142327   Click image for larger version
ID:	142328   Click image for larger version
ID:	142329   Click image for larger version
ID:	142332   Click image for larger version
Shaun
my x2 conversion ------> http://www.cnczone.com/forums/showthread.php?t=36403
  #66   Ban this user!
Old 09-19-2011, 11:57 PM
dsquire is on a distinguished road
Steve
Have you given any more thought to putting one of your V8's into a boat now that you re close to having them finished?
Cheers
Don
  #67   Ban this user!
Old 09-20-2011, 02:03 AM
Mago is on a distinguished road
Quarter scale Offenhauser
Hi guys,
Some pics of the completed Offenhauser model, plans by Ron Colonna.
Took almost 2 1/2 years to build and if I had studied the plans more carefully would have realised that it's a very complex bit of machinery, especially in this scale.
Cam box covers removed to display cams.
It is set up to run but might end up as a desk top display.
Mago
ID:	142339   Click image for larger version
ID:	142340   Click image for larger version
ID:	142341   Click image for larger version
  #68   Ban this user!
Old 09-20-2011, 09:49 PM
CIMG4217.AVI - YouTube
You might be surprised how small you can go with carby size. When smaller, the engines tend to behave themselves much better. Try something from a .10cu in motor. The 4 cylinder inline engine I built (above) 25cc runs on homemade carby with a 2mm venturi and it will run to 10,000rpm.
  #69   Ban this user!
Old 09-21-2011, 10:38 PM
hmm, interesting. So start small, then work your way up. How would a small carb affect RPM? and how did you figure out the carb size for you engine?
Shaun
  #70   Ban this user!
Old 09-27-2011, 11:47 PM
Quite simple really.....experience....I've done it before and like you, I had size too large. i.e. engine was cranky to start, run and adjust. Fuel draw was poor also. So I cut back until it worked properly. If you look at the design of the carby they use on the V4 Howell engine you will get some idea. I have built one of the Howell carbies and with the idle bar and the main jet bar in the venturi, even I wonder if there will be enough airflow. But it works on the original V4 so there you go.
The Howell V-4 IC Engine Project
Howell 2-Jet Throttle
GHQ engines T.L.A.R. eng I.C. Engines 3 11-26-2007 05:10 PM
Rotating cylinder engines CNCgr I.C. Engines 4 07-01-2007 10:54 AM
rose engines zonker Mechanical Calculations/Engineering Design 3 03-29-2006 03:10 AM
Can not post pictures (klutz) need help Adobe Machine Forum Questions or Problems 3 03-25-2006 10:04 AM
post multiple pictures georgebarr Forum Questions or Problems 2 02-26-2004 01:23 AM
