| I.C. Engines Discuss home made Internal Combustion engines here! |
| Hi, If you're planning on building a machine, I would simply go with a 4-axis CNC mill. Something like a desktop mill (Sieg X3 maybe???) with a fourth rotary axis would probably do, depending on how big your liners are. You could then mount the liner on the rotary axis and proceed to mill the ports. With a setup like this, your porting possibilities would be almost endless and they would also be repeatable. The other advantage of using a mill is that it is useful for so many other things too. It wouldn't just be limited to cylinder liners. I hope this helps. Regards Warren
__________________ Have a nice day... |
| Fabled in story and song. I built a CNC hotwire several years ago and now I'm working on a CNC router largely based on Joe2006chevy's 2006 r2 model. |
| I have done extensive work on 2 strokes. The best tools for this are hand grinders......but please dont think "dremel" when I say that. Unless you are just planning exhaust and intake work, you need a real good collection of straight, 45 degree, and right angle grinders and a Foredom (or similar) flex shaft machine to properly reach the transfer ports. This is about a 300 dollar tool, look for CC Specialty tools, or Gesswein for the right angle tools. Most of the work is actually on the paper - designing the shapes and areas. |
| Hi, I assumed you were talking about liners, so my suggestion is probably not the best for complete cylinders. Maybe you could supply a few more details. Are you making completely new cylinders or are you trying to modify the standard factory cylinders? Regards Warren
| It's just an exercise, really. I can send a block out and have it done up for a couple of thousand so there isn't a ton of money to be saved. It's more a matter of wanting to do it myself. Any time I've seen an engine that someone has opened the rod slots, lightened pistons, or whatever... with a die grinder, it always looks like it was done by rats. I would love to be able to get all cylinders identical within about 0.002" and have it look like it is a stock port map. |
