Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > I.C. Engines
I.C. Engines Discuss home made Internal Combustion engines here!
  #37   Ban this user!
Old 06-21-2006, 08:34 PM
balsaman's Avatar
balsaman is on a distinguished road
Crap, wrecked the first chunk of aluminium....
It's been a couple months and I forgot to subtract the edge finder radius when I zeroed the stock.
Will cut another.....
I wish it wouldn't crash.
Old 06-22-2006, 02:29 AM
*Registered*
nick.gilling is on a distinguished road
Well never mind, at least you know where you went wrong!!!
Be sure to post up pics of the results.
Nick
Old 06-30-2006, 03:28 AM
*Registered*
Hi Eric,
Engine is looking good. How are the cams locked onto the shaft?
Any more progress? Any luck with the machining this time?
Nick
  #40   Ban this user!
Old 07-01-2006, 05:20 PM
balsaman's Avatar
I was away for a week. Be back soon with more progress....
Eric
  #41   Ban this user!
Old 07-09-2006, 03:10 PM
balsaman's Avatar
First chunk is in progress...before and after. More operations to do on this part. It's the top half of the crank case.
ID:	19722   Click image for larger version
Old 07-09-2006, 04:32 PM
*Registered*
Good wor there, very interesting to see this one come together.
  #43   Ban this user!
Old 07-09-2006, 08:08 PM
balsaman's Avatar
nice radius'
  #44   Ban this user!
Old 07-10-2006, 07:54 PM
balsaman's Avatar
more progress
ID:	19769   Click image for larger version
Old 07-11-2006, 02:22 AM
*Registered*
Looking good, you must be chuffed with your DIY cnc mill!
How many cuts did it take to profile the inside? How long did it take?
Also, how did you cut the external radii? with some kind of router bit?
Excellent stuff!
Old 07-11-2006, 02:27 AM
*Registered*
or did it just take a lot of cuts stepped down?
You've probably gathered I don't have a clue how a CNC works!
  #47   Ban this user!
Old 07-11-2006, 11:45 AM
balsaman's Avatar
I love my mill.
Inside took an hour or so to cut out with a .25 em., .050 deep steps down.
Outside radii was done with a .375 ball mill with .005 step over
I used a cheap edge finder to find the edge for the inside pocket and that's the last time I use it. The inside pocket is out by over .010. Won't matter but it bugs me.
Eric
  #48   Ban this user!
Old 07-11-2006, 07:58 PM
Stevie is on a distinguished road
Eric
Use a 1/4 dowel pin
Run it about 500rpm
Lightly touch it with a magic marker
Move it to the edge very slowly (like 0.001 at a time)
Once you see a scuff of the black and see the steel showing through; you have the edge
Tags
2 cylinder inline, camshaft, edrawings, hemi
