Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > I.C. Engines
I.C. Engines Discuss home made Internal Combustion engines here!
  #25   Ban this user!
Old 08-30-2008, 03:50 PM
sorveltaja is on a distinguished road
Down-scaled Webster
Anyone here built/building smaller version of Webster?
My previous project was Ringbom-type Stirling engine, and now I have started to build Webster, that has 7mm(0.275") bore, and 10mm(0.393") stroke.
Base, supporting columns, crankshaft and connecting rod are made so far.
Gears are from my junkbox, and are ready-made.
Needless to say, that I have to make spark plug also. It's going to have about 3mm(0.118") diameter, and M3 thread. Insulator will be made of teflon.
Making spark plug(s) is totally new subject to me, and definitely trial-and-error process. Nevertheless, interesting to try.
Igniter will be piezo-operated to eliminate coil and/or battery, something like Maier's engines use.
Instead of venturi and needle, I'm going to use petrol vapour carburetor.
  #26   Ban this user!
Old 09-02-2008, 02:42 AM
8inlinea is on a distinguished road
since the original site with plans is now offline, has anybody saved a copy of the plans?
thank you!
  #27   Ban this user!
Old 09-02-2008, 04:29 AM
Webster plans
thank you!
I downloaded mine from http://home.comcast.net/~webster_engines/ , and it seems to be online.
Link to PDF plans is on the bottom of the page.
  #28   Ban this user!
Old 09-02-2008, 04:56 AM
great, thanx!
  #29   Ban this user!
Old 09-02-2008, 09:48 AM
Webster wip
Here is some sketching:
and pieces made so far:
The block that will be holding valves, exhaust pipe and carburetor, is vertically slightly oversized, and simplified so that it is made from one piece, instead of three-piece that mentioned in original drawings.
That block has already M4 thread in it, so that valve guides can be screwed into it. Does it work, I can't say until I've made some more parts...
Other modification is to make cylinder that has brass or aluminum cooling fins, and iron cylinder liner, instead of making whole thing totally from iron.
