Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > I.C. Engines
I.C. Engines Discuss home made Internal Combustion engines here!
Old 04-09-2011, 03:51 PM
Adaware is on a distinguished road
Size on inlet and outlet ducts?
Two valves per cylinder. How big should the inlet and outlet port be?
Cylinder volume if about 40-50ccm
Don't need racing specs here. Just want it to be reasonable :-)
Old 04-09-2011, 04:08 PM
stevehuckss396's Avatar
stevehuckss396 is on a distinguished road
I try to keep them 1/3 the size of the bore. Don't know why, just know it works.
Old 04-09-2011, 08:08 PM
dynosor's Avatar
dynosor is on a distinguished road
What Steve said sounds good. If you get greedy with large ports the gas flow velocity suffers. This degrades fuel atomization and low speed cylinder filling, leading to very hard starting and poor low speed performance. Err on the small side.
Red to red and black to black, or it's ashes to ashes and dust to dust.
Old 04-09-2011, 08:42 PM
Hmm, 12-14mm is the best i can do in this engine. Like i said in the other thread it's very limited space on this engine. Maybe i will post a thread about it.
It's not a project in the making but more like a cad project while learning to draw in Solidworks. The thing is that i want the engine to actually be buildable so i need sizes that's possible to work with
Thanx once again for help
Outlet height TarHeelTom Safety Zone 2 05-09-2010 01:25 PM
Water inlet replacement for those Chinese spindles ennova DIY-CNC Router Table Machines 2 04-12-2010 06:40 AM
Machine Tripped GFI Outlet! Phishaholic Tormach PCNC 7 10-29-2009 11:29 AM
220v Outlet Questions pzzamakr1980 General Electronics Discussion 4 08-25-2008 11:41 PM
Gecko Factory outlet...and more Bloy2004 Gecko Drives 27 12-30-2004 04:25 PM
