Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > I.C. Engines
I.C. Engines Discuss home made Internal Combustion engines here!
Old 03-21-2011, 08:11 PM
doc0455 is on a distinguished road
6 cycle engine
Here a a video of my 6 cycle engine I built about 7 or 8 years ago. I put a smaller base under it today and spent some time playing with it.
YouTube - 6-Cycle Hit miss engine
Old 03-21-2011, 10:30 PM
Gold Member
Ken_Shea is on a distinguished road
Sounds real good, I liked the thumpy sound.
What is the 6 cycle referring to beyond the normal 4?
Old 03-22-2011, 11:54 AM
It has extra exhaust cycles suppose to be more efficient and run cooler.
Old 12-06-2011, 03:58 PM
Ken McKenzie is on a distinguished road
wankle engine
Yes it is the wankle engine it is a word and not a name.
The Wankel engine consists of a rotary piston with interior gears that are in a three to two ratio for example the rotor has 30 gear teeth and the stationary gear has 20 teeth. The old Mazda engines had 2X17=34 stationary gear teeth and 3X17=51 interior ring gear teeth. In one revolution of the e-shaft the rotor is held stationary two thirds of a revolution therefore it advances one third.
The wankle engine is different it's gear ratio is different. It has a 32 tooth stationary gear and a 24 inch spur gear attached to the rotor. In one clockwise revolution of the e-shaft turns the rotor 1/3 revolution counter clock wise. The combustion at top dead center creates energy like a bullet out of a rifle.
It is a fact of life little known that energy is created by creating an imbalance.
It is probable that the gear ratio can also be 24 to 40 with double the e-shaft throw.
Any interest I have plans and the gears.
Old 12-20-2011, 03:41 PM
jwolin's Avatar
jwolin is on a distinguished road
I'd love to see this entered in the cncmentor.com build log competition....impressive!
http://cncmentor.com - open source sharing community and CAD Library
Heidenhain iTNC 530: Using Cycle 19 and Cycle 8 Dan B General CNC (Mill and Lathe) Control Software (NC) 4 08-27-2011 11:32 AM
Search drawing from free piston engine ->stelzer engine Enginetuner I.C. Engines 17 08-27-2010 08:11 PM
my another new engine.... OG LIM Steam Engines 0 08-12-2008 05:55 AM
sequential cycle rotary engine (SCRE) dr kingston I.C. Engines 9 03-22-2007 04:34 PM
Atkinson cycle engine mark c I.C. Engines 4 01-21-2007 09:50 AM
