04-11-2010, 01:19 AM
Originally Posted by eject_21 Here's my stupid question... Why do radial engines need to have an odd number of cylinders?
Could you have a twelve cylinder radial engine?
(Four cycle implied) |
Conventional single row radial engines share one crank pin by means of what is called a master connecting rod. As such, odd numbers of cylinders result in a smoother running engine: An even number of cylinders would imply that pairs of opposing pistons would move together such that when one piston is at tope dead center, its mate is at bottom dead center. The vibration characteristics of such an engine would be similar to an engine with half as meany, but twice as heavy pistons. http://upload.wikimedia.org/wikipedi...gine_large.gif
As for even numbers, 10, 14 and 18 cylinder radial engines exist, but use two rows of 5, 7 or 9 cylinders.
__________________ Red to red and black to black, or it's ashes to ashes and dust to dust. |
