Mini Bike - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 21 to 40 of 56
Thread: Mini Bike
  1. #21
    Jan 2006
    Quote Originally Posted by CNCadmin View Post
    Amy updates?
    You lookin for hourly progress reports or what?
    Matt
  2. #22
    Member stevehuckss396's Avatar
    Dec 2006
    Quote Originally Posted by keebler303 View Post
    Matt
    Good one!! LMAO
    I started on the fixture to assemble the front forks today. Shouldn't be more than a week.
  3. #23
    Dec 2006
    I have finished the fixture to assemble the handle bars. It will hold all the brackets in the proper
    place and hold the bars at the correct angle for assembly. I will also be able to drill the holes for
    the front axle thru the blocks to correctly locate them.
    You can see why it's going so slow. My fixture to mini bike ratio is pretty low.
  4. #24
    Dec 2006
    Quote Originally Posted by Rita298 View Post
    Any updates?
    Hahahahahaha!!!!!!
  5. #25
    Oct 2005
    Man that's nuts!
    What's the expected production quantity of bikes you will be making?
  6. #26
    Dec 2006
    Quote Originally Posted by RomanLini View Post
    Man that's nuts!
    One
  7. #27
    Dec 2006
    Made some forward progress today. Got the forks about 80% done. Forward motion today!!
  8. #28
    Dec 2006
    Made the die to crimp the forks down by the axle. Works well and is almost exact to the real fork. I tested it on a scrap piece of tube and it looks good. The crimp is not exactly centered because I was too lazy to drill the tube to pin the die before testing.
  9. #29
    Dec 2007
    That is too freakin cool! Love it!
    Obligatory Zoolander quote, "What is it? A bike for ants?"
    Can't wait to see more of this project,
    Ian
    It's a state of mind!
  10. #30
    Jun 2007
    I'll have to remember the die crimp trick. Nice job!!!
  11. #31
    Dec 2006
    The die worked perfectly. The frame is done! Now I can move on to something else but I am not sure which way to go.
  12. #32
    Member FannBlade's Avatar
    Jun 2011
    That looks really GOOD!
    I take it you will be building motor from scratch also?
  13. #33
    Dec 2006
    Quote Originally Posted by FannBlade View Post
    Yep! It's going to be another long one.
  14. #34
    Member kd4gij's Avatar
    Feb 2011
    Ah come on put the Demon in that sucker
  15. #35
    Dec 2006
    Quote Originally Posted by kd4gij View Post
    You sir are a genius!
  16. #36
    Dec 2006
    I finally have a frame in rolling form. I made the rims and other axle parts today. I had to make the axle bolts and bolts to hold on the forks. #12 bolts are not easy to find.
  17. #37
    Member LouF's Avatar
    Sep 2011
    Great work very impressive what type of power plant?
    Lou
    http://www.cnczone.com/forums/diy-cnc-router-table-machines/140832-cnc-software.html
  18. #38
    Dec 2006
    Quote Originally Posted by LouF View Post
    Lou
  19. #39
    Sep 2011
    4 stroke ?
  20. #40
    Dec 2006
    4 stroke ?
    Of course. Anything else would be uncivilized.
Mini Bike
Mini Bike
