| Hyundai Kia machine Discuss hyundai kia machine here! |
I am not quite grasping how the work offset is set with the LX3 controller. In my other turning centers you simply bring the tool up to the end of the stock , touch the end of the part , and press the work offset button and the values are entered . Could someone give me an Idiots primer on setting work offset with the LX3/kt15? |
| On the LX3.. to set the Z axis offset after touching off front of part: Use P0 then input This will set the zero automatically. Also, if you touch off the front of the part and want to set the machine to take off .010 off the face, you just input P.010 and it will automatically set the Z in .010. As for your other post, the x axis can only be changed in the parameters. We have had these machines for about 15 years and never had to change the "x" axis. Hope this helps |
| System Variable Z Work Shift | ggborgen | Parametric Programing | 3 | 11-25-2009 11:57 PM |
| work shift | teamus | Hardinge Lathes | 22 | 06-10-2009 05:32 AM |
| Problem- c axis work shift | Atlas_Too | Fanuc | 3 | 10-13-2008 12:14 PM |
| Setting Z axis with G92 work shift | venomgrrrl | Fanuc | 12 | 12-03-2007 11:02 AM |
| offset shift and part off | nitemare | Daewoo/Doosan | 1 | 03-03-2006 09:49 PM |
