is there possibly a parameter or setting that controls the depth of the finish pass?
I need a little help writing the the g76 line to thread with yasnac lx3 controller.
I have been lax in learning basic canned cycles as my other 2 turning centers have really easy to use conversational programing and to date I have not needed to know the how and why , just enter a few parameters , maj, minor pitch and depth per pass and cut the threads.
I have spent the day going thru the 4 pages in the manual that relate to g76 and have written the following which is intended to cut .75x20 tpi . Everything appears OK but it cuts the final pass at a depth of .006" , 2 x my D value.
Is there a way to enter a value for depth of finish pass and any way to callout spring passes (multiple finish passes at the final depth)?
T300
M8
G00 X.755 Z.1
G76 X.7 Z-.75 K.025 D.003 A60 F.05
M9
M30
Setting #6206 is the minimum depth of cut. I can't find any reference to spring passes. I believe you have to program these individually. I think the example below would take 2 spring passes since D must be less than K. Try it away from the part 1st.
T300
M8
G00 X.755 Z.1
G76 X.7 Z-.75 K.025 D.0249 A60 F.05 (2 SPRING PASS)
M9
M30
I will give it a run in the morning
If you want absolute control over the depth of cut and as many spring passes as you like use G92.
g92 will solve the problem, was just hoping to do it all in one line
