Results 1 to 5 of 5
Thread: which param to adjust tool setter on kt15/21?
    Aug 2004
    us
    What parameter adjust the tool setter x axis on kia kt15 , mine is off .0025
    Registered dcoupar's Avatar
    Mar 2003
    See the attached excerpt from the manual.
    Attached Thumbnails Attached Thumbnails which param to adjust tool setter on kt15/21?-lx3_tool_setter_parameters.jpg
    Aug 2004
    us
    perfect, many thanks, could you give me a little input on how to move cursor over to bit I want to change in param mnetioned in my other thread
    Mar 2003
    It's been a long time, but...
    If your machine has a tape reader, there should be a System No. thumbwheel switch in the tape reader compartment. Set it to "1" to change parameters. If your machine doesn't have a tape reader, you'll have to use setting #6219.
    #6219 is a setting, not a parameter, so you need to be in SET not PRM to change it. Normally it's set to "0", but to change parameters, you need to change it to a "1".
    MDI - SET - 6219 - Cursor down - 1 - WRITE.
    Now change parameter #6618 (write down the old value before changing... just in case).
    PRM - 6618 - Cursor down - key in new value - WRITE
    If you need to change one of the "bit" parameters, after the Cursor down, press INSRT. The cursor should move to the 7th bit. Cursor down to highlight the bit you want to change. Press WRITE to toggle the bit. Press INSRT to get the cursor back into the left column.
    Go back to SET and change #6219 back to 0, or set the thumbwheel switch back to 0.
    But don't quote me on this.
    Aug 2004
    us
    Many thanks, it was my confusion over setting 6219 and parameter 6219 that had thrown me off
    1. Need Help!- Tool Setter Macro for M-V60C and Metrol Setter
      By mitshack in forum Mazak, Mitsubishi, Mazatrol
      Last Post: 02-02-2013, 06:08 AM
    2. kt15 indexing tool disk/turret?
      By panaceabea in forum Hyundai Kia machine
      Last Post: 01-22-2010, 10:31 AM
    3. Need Help!- Nl2500 Tool setter How to adjust
      By sjlbwig in forum Mori lathes
      Last Post: 02-11-2009, 05:43 PM
    4. Need Help!- Tool setter macro for M-V60C and Metrol setter
      By mitshack in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 10-06-2008, 09:38 AM
    5. Tool Setter
      By GARY DAVIS in forum Fadal
      Last Post: 03-18-2008, 08:44 PM
