Results 1 to 6 of 6
Thread: Need help restarting a program at a tool with a Kia Turn 15 w Yasnac LX3 controller
    Registered Jonsmachine's Avatar
    Jun 2006
    Question Need help restarting a program at a tool with a Kia Turn 15 w Yasnac LX3 controller
    Question for you guys.
    We just got this Kia Turn 15 lathe with the Yasnac LX3 controller and I can't figure out how to restart a program somewhere mid program, I have to start all the way from the beginning. At least if I can start at a tool change or something it would be helpful. The poorly translated manual is almost useless and has been of no help, I have no problem doing anything else and I know how to do this on my other machines so if anyone can enlighten me on this, it would be very much appreciated.
    Thanks in advance for your help.
    - Matt
    Moderator HuFlungDung's Avatar
    Mar 2003
    The way I do this on a Mitsubishi is to do a line search in the main program window. The tricky part is making sure everything is in the correct state to run the program safely. So I make sure that everything is spelled out with every tool change so that spindle clamp speed, spindle speed, IPR/IPM, CSS/RPM is all there to get running as expected, otherwise some nasty surprises can occur.....like spindle running up to top speed in a hurry
    Registered maz43's Avatar
    May 2009
    I run A KIATURN15 with a Yasnac 2.
    I don"t use program restart. I cursor down to the N number at the tool change I want to go to. I my case I home both axes first .
    O0003
    (RCP-025/IST OP)
    G0G99
    G0G28U0W0
    N1T100(FACE/OD)
    G0X.45Z0.G97S1400M3
    M8
    G1X-.03F.003
    G0X.295Z.05
    G1Z-2.06F.003
    X.4F.005
    G0Z.05
    X.12
    G1X.27Z-.025F.002
    U.006Z-2.06F.003
    X.4F.005
    G0Z.1
    G0G28U0W0
    M1
    N2T200(#3 CENTER DRILL)
    G0X0.Z.2G97S1100M3
    M8
    G1Z-.19F.0015
    Z.1F.05
    G0G28U0W0
    M1
    Registered dcoupar's Avatar
    Mar 2003
    I agree with maz43. However, I'd put N2 on the G00G28U0W0 above the M01. That way you don't have to home the machine first. Just search for N2, and Cycle Start.
    Jun 2006
    Quote Originally Posted by HuFlungDung View Post
    Yes, absolutely. I've ran into that situation on my other machines. Thanks
    Quote Originally Posted by maz43 View Post
    O0003
    (RCP-025/IST OP)
    G0G99
    G0G28U0W0
    N1T100(FACE/OD)
    G0X.45Z0.G97S1400M3
    M8
    G1X-.03F.003
    G0X.295Z.05
    G1Z-2.06F.003
    X.4F.005
    G0Z.05
    X.12
    G1X.27Z-.025F.002
    U.006Z-2.06F.003
    X.4F.005
    G0Z.1
    G0G28U0W0
    M1
    G0X0.Z.2G97S1100M3
    M8
    G1Z-.19F.0015
    Z.1F.05
    G0G28U0W0
    M1
    Thanks, i'm going to try that soon. Should be running parts on it in a couple hours.
    Quote Originally Posted by dcoupar View Post
    Good input, thanks.
    - Matt
    Jun 2006
    Turns out it was as simple as typing in my line, "N123" and pressing the cursor down arrow "↓" while in Memory mode (not edit). This brought the program straight to my requested line and I proceeded with cycle start.
    Thanks guys.
    - Matt
    1. Replies: 4
      Last Post: 06-06-2009, 09:01 AM
    2. Mazak Program Restarting...
      By Bloodeye in forum Mazak, Mitsubishi, Mazatrol
      Last Post: 06-07-2008, 08:28 AM
    3. Restarting in mazatrol program
      By Castle1 in forum Mazak, Mitsubishi, Mazatrol
      Last Post: 07-03-2007, 07:43 PM
    4. Stopping and Restarting in a Program
      By Dugg in forum Haas Mills
      Last Post: 01-14-2007, 04:32 PM
    5. question about Yasnac tool offset in the Z
      By DDuley in forum Machine Problems, Solutions , Wireless DNC, serial port
      Last Post: 02-18-2006, 08:23 PM
