Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Hyundai Kia machine
Hyundai Kia machine Discuss hyundai kia machine here!
Old 10-16-2009, 01:06 PM
inthedark's Avatar
inthedark is on a distinguished road
KiaTurn15 Yasnac LX3 help
I have this older KiaTurn 15 with a Yasnac LX3. After numerous problems with the control, hopefully it is ready for use.
Below is my coding and after it clears the offset "T0300" and goes to the new tool "T0202". It takes off in the wrong direction. I am unsure of the problem at this point.
If anyone is familiar with this control, could you take a look at the following code and tell me where my feeble brain is messed up? Am I mis-using the G50 on this machine?
I am open to suggestions...
Thanks,
O0003
G20G40
G50 X7.136 Z8.90
G0 S700 M03 T0303
M08
G00 X1.25 Z0.06
N80 G71 P90 Q260 U0.002 W0.002 D0.025 F0.008 S700
N90 G01 X1.164 Z0.06 F0.008
N100 G01 X1.164 Z0.
N110 G01 X1.164 Z-0.02
N120 G03 X1.1529 Z-0.038 I-0.032 K0.
N130 G02 X1.1529 Z-0.132 I0.0692 K-0.047
N140 G03 X1.1529 Z-0.168 I-0.0265 K-0.018
N150 G02 X1.1529 Z-0.262 I0.0692 K-0.047
N160 G03 X1.1529 Z-0.298 I-0.0265 K-0.018
N170 G02 X1.1529 Z-0.392 I0.0692 K-0.047
N180 G03 X1.1529 Z-0.428 I-0.0265 K-0.018
N190 G02 X1.1529 Z-0.522 I0.0692 K-0.047
N200 G03 X1.1529 Z-0.558 I-0.0265 K-0.018
N210 G02 X1.1529 Z-0.652 I0.0692 K-0.047
N220 G03 X1.1529 Z-0.688 I-0.0265 K-0.018
N230 G02 X1.1529 Z-0.782 I0.0692 K-0.047
N240 G03 X1.164 Z-0.8 I-0.0265 K-0.018
N250 G01 X1.164 Z-0.91
N260 G01 X1.25 Z-0.91
M09
G0 X7.136 Z8.90
T0300
G20G40
G50 X8.654 Z7.4283
G0 S800 M03 T0202
M08
G00 X0. Z0.05
G01 X0. Z-0.05 F0.004
G00 X0. Z0.05
M09
G0 X8.654 Z7.4283
T0200
G20G40
G50 X8.654 Z2.2283
G0 S1200 M03 T0606
M08
G00 X0. Z0.05
G01 Z-0.5 F0.004
G0 Z0.2
Z-0.45
G01 X0. Z-1.
G00 X0. Z0.05
M09
G0 X8.654 Z2.2283
T0600
G20G40
G50 X8.654 Z7.154
G0 S600 M03 T0404
M08
G00 X0. Z0.05
G01 X0. Z-0.75 F0.004
G00 X0. Z0.05
M09
G0 X8.654 Z7.154
T0400
G20G40
G50 X9.543 Z9.2
G0 S600 M03 T0101
M08
G00 X1.3 Z-0.83
G01 X0.04 F0.002
G00 X1.3
M09
G0 X9.543 Z9.2
T0100
M05
M30
"Plan your work; Work your plan"
Old 10-16-2009, 04:23 PM
inthedark's Avatar
My issue is resolved, basic idea is below
G0 T0303
G50 T5303 Sets offset out of a table
Work cutting moves here
T0300 clears offset
G0 X0.0 Z0.0 takes turret home
Old 10-17-2009, 05:26 PM
maz43's Avatar
maz43 is on a distinguished road
I run a Kiaturn21 with an old Yasnac control.
Tool offsets are very basic on these controls.
T100 will call tool 1 and offset 1.
G0G28U0W0 will return tool to home.
T200 will call tool 2 and offset 2.
GOG28U0W0 will return home.
Also when using G71 if your start point in X doesn't match your last X value in the canned cycle code you will get an alarm. This drove me nuts until I figured it out.
Old 10-27-2009, 06:05 PM
inthedark's Avatar
I will keep that in mind.
Yasnac mx1 vs. mx5 Brian FRF General Metal Working Machines 0 06-10-2009 12:32 AM
Yasnac help cncwhiz General Metal Working Machines 12 03-25-2009 07:48 PM
Need Help!- Yasnac LX3 inthedark General Metalwork Discussion 2 08-07-2008 06:03 AM
yasnac J 100 M Furlan Manual Machining Tooling 0 11-17-2007 10:55 AM
Yasnac I80 Gitanes General CNC (Mill and Lathe) Control Software (NC) 0 11-24-2005 12:00 AM
