Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Hyundai Kia machine
Hyundai Kia machine Discuss hyundai kia machine here!
Old 06-29-2009, 09:02 AM
Get lucky's Avatar
Get lucky is on a distinguished road
Work Light
I have two hyundai Kia vx500 Machines that the work lights will just sit and flicker and will not turn all the way on. If anybody has a solution to fix this I would gladly listen
Thank you,
Kyle
You must remember that 99% of my posts are Bullchit!
Old 06-29-2009, 12:33 PM
Boots is on a distinguished road
Sounds like a bad connection. I'd take out the bulbs and clean the contacts, try that. If that doesn't help they might just need to be replaced. Do not touch the blubs with your bare hands. The oils on your skin will cause the bulb to blow when you turn it on. Wipe off fingerprints with alcohol.
Old 06-30-2009, 07:40 AM
Get lucky's Avatar
The bulbs are not halogen they'er fluorescent I tried the starters but didn't fix it i was thinking if it had a balist maybe not wouldn't even know were to start looking for that.
Old 06-30-2009, 02:55 PM
I didn't realize they were fluorescent. But you're right in thinking ballist maybe the problem if it has one or the starters. Bad starter will cause flickering. Did you check the pins in the bulb for corrorison? That green stuff.....
Old 06-30-2009, 02:58 PM
You might want to try some dielectric grease on the connections also...it helps.
Old 07-01-2009, 03:16 PM
Get lucky's Avatar
Had the teck. in today and confirmed that the ballast in both machines are junk and kia won't sell just the ballast have to buy the light so I will have to figure something else out
a ring of 200 Led Lights to light up? light source render? Rich05 Solidworks 6 10-25-2008 07:16 PM
Problem- VF-2 Work Light Out akedward Haas Mills 19 02-19-2008 01:37 PM
Work light connector over heating GITRDUN Haas Mills 2 08-29-2007 04:54 PM
Machine Recommendations Please - Light Duty, Prototyping, Light Production in metal SCG11762 General Metal Working Machines 2 08-27-2007 09:08 AM
Chicago: Access to shop in return for light work vacpress Mentors & Apprentice Locator 3 11-14-2006 11:43 PM
