Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Hyundai Kia machine
Hyundai Kia machine Discuss hyundai kia machine here!
Old 07-09-2008, 12:12 PM
rikonen is on a distinguished road
Meldas 520
Does anyone know how to get the parts counter to keep track of the amount of parts being run? All the values are empty on the counter screen, I have tried a few things with no luck.
RI
Old 07-10-2008, 02:40 AM
mori_1 is on a distinguished road
Smile does your machine except macros?
if your machine accepts macros you could add in something like this to count parts:
O1000
#100= 1 (this sets the #100 value to 1, "your first part")
N1
TI
M6 (Or T0101 LATHE)
MAIN PROGRAM
(parts catcher out "M" code here)
(part off tool code here)
(parts catcher in "M" code here)
#100=[#100+1] (increments your #100 value to 2 "your second part")
M99 (normally here but instead of M99 use a GOTO 1-program will jump back up to the N1)
This will keep incrementing the #100 macro value by 1 at each parts catcher in/out giving you a part count.
If you want to run say only 30 parts: between the #100=[#100+1] and the GOTO 1, put in a IF [#100 LE 30] GOTO 1 followed by an M30. After running 30 parts the program will end at the M30. Pressing cycle start will reset your counter (#100 value) to 1 and continue to 30. Hope that helps
Old 07-10-2008, 11:15 AM
Gold Member
Caprirs is on a distinguished road
There is an M code you place in your program to increment the parts counter on your machine. Normally, it is placed just after the parting tool cuts off the part and before the M99. The M code is typically selected by the builder, not necessarily by Mitsubishi.
Meldas 310 zvizdic Mazak, Mitsubishi, Mazatrol 2 03-06-2008 11:40 AM
meldas 300 positiverake Mazak, Mitsubishi, Mazatrol 4 02-24-2008 09:57 PM
Meldas 310 mmurning Mazak, Mitsubishi, Mazatrol 1 06-20-2006 11:37 AM
Meldas 500 pete v Mazak, Mitsubishi, Mazatrol 4 02-08-2006 05:17 PM
DNC for Meldas hpowell General CAM Discussion 2 04-06-2004 02:18 PM
