Results 1 to 2 of 2
Thread: Hyundai Kia SKT21L turret problem
    Jul 2008
    Finland
    I have recently purchased a SKT21L (used -07).
    Control system is Fanuc 21i-TB.
    A backup battery for absolute encoder for turret servo was dead.
    After change of battery there is alarm #2062.
    Problem is that i did not get the correct manuals with the machine.
    I have the Fanuc manuals but not the manufacturer manuals.
    According to Fanuc servo drive manual B-65395 the error displayed on the LEDs on servo unit is alarm number 319.
    Description from Fanuc manual:
    "When the absolute pulse coder is used, the motor has not yet rotated through more than one turn after the first power-up"
    Countermeasure:
    "Cause the motor to rotate through more than one turn in jog feed mode,
    then turn the power off then back on."
    Do you have any tricks to get the turret jog started?
    I´ve tried to jog it but i am not sure if i use the right key combinations.
    Any help appreciated!
    Nov 2006
    India
    Turret zero setting
    Change keep relay #K5.0 to "1"
    Simultaneously press 'Spindle select' & 'Spindle stop' & 'Feed hold'
    Now turret will get unclamped. Rotate the disc by hand. Match the markings (there will be markings on the moving & non moving parts)
    Press 'Call buzzer OFF' button.
    Simultaneously press 'Mode select' & 'Spindle stop' & 'Feed hold'
    Change Keep relay #K5.0 to '0'
    Reset. Finish.
  1. HAAS SL-20 TURRET PROBLEM HELP
    By allmotormatt in forum Haas Lathes
    Last Post: 01-20-2011, 12:47 AM
  2. FANUC 6T Turret Problem
    By kulbir in forum Fanuc
    Last Post: 04-14-2010, 03:33 AM
  3. Just IN- turret problem for takisawa tc 2
    By anantwaykole in forum CNCzone Club House
    Last Post: 12-29-2008, 09:03 AM
  4. Hyundai Hit 8s Problem
    By dillweed in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 11-02-2008, 08:22 AM
  5. SL 10 turret problem
    By PBMW in forum Haas Mills
    Last Post: 08-15-2006, 09:51 PM
