- Need Help!- Hyundai Hit 20, Siemens 840d bios battery
I have an 840 d control that needs its bios battery changed every 30 days. This just seems wrong. Does anyone have any thoughts on this?
What should the approximate life of this battery be. What could be wrong here.
Any input would be appreciated.
Re: Hyundai Hit 20, Siemens 840d bios battery
5 or so years for the battery, that little round lithium should last at least that long. I ended up soldering in a 2/3A holder with the lithium on ours, so I don't have to go through all the work. If yours is dying in a month, either you are getting old stock batteries or your MB has an issue.
Sent from my A3-A20FHD using Tapatalk
I agree, my other machines batteries last at least 5 years as well.
I just purchased the machine and they sent me instructions on how to change the batteries after the purchase before I even had it powered up! Not good. I hope they've just been using poor batteries. I've sent away for the Siemens recommended batteries. I'll see whats going on then.
Thanks for your input. I hope I don't need to be looking for an electronic problem.
- You may not post replies
- You may not edit your posts
Forum Rules
