Have you tried to use the X command rather than the P?
Best regards,
hi we have a kia lathe 21lms fanuc io-tc
we using CAN cycle for grooving G75 and need a dewell on the bottom of the groove
(groove botton x96. metric.)
ex:
X100.
G75 R7.
G75 X96.7 Z259.625 P1500 Q 0775 R0 F.1
( Z259.625 =PITCH Q.775MM )
i try to put a dewell BEFORE AND after the
G75 R.7
G04 P3000 AND IT NOT WORKING
any sugestiong thanx
Best regards,
Experience is what you get just after you needed it.
what do you mean X command
replace P for as X
can't cause i already have X96.7 2 X can't be on the same line
I meant try the G04 X3.0 for 3 second dwell.
Best regards,
not working i think the dwell have to be on the same line of G75 X96.7 Z259.625 P1500 Q 0775 R0 F.1
I do not believe that the G75 cycle has the ability to add a dwell in the cycle.
Some of the other cycles such as G83 have the ability but are typically used for drilling.
