Normally you can just pulse handle away from the limit and then press the reset to clear the alarm. If this is not working then I think I would check for a sticky overtravel switch that may not be releasing after you move away.
Best regards.
hello. new to the cnc zone forum. im having issues getting the x overtravel message to disappear. after i overtravelled in x-, i rehomed it. can still get everything to home position, but cannot handle or jog x axis anymore. we just bought this used machine and havent even been able indicate tombstone. any advice would be greatly appreciated.
Best regards.
Experience is what you get just after you needed it.
not having that problem today. the machine sat overnight. guess it took that amount of time for something to become unstuck. thanks again for the insight.
