- Hyundai Kia SKT180 Wait Code Problem
Hey guys,
I've got a Hyundai SKT180 TTSY with a Fanuc 18i control. If you're only running one turret and have the other in EDIT mode the program that's running will skip all wait codes and run the program as if they don't exist. This has caused a crash as an operator accidently hit EDIT to switch between heads to make a comp instead of hitting MEMORY. Has anyone else had this issue or know how to fix it? I've got an SKT200 TTSY with the same controller and it works as it's supposed to.
Thanks.
Re: Hyundai Kia SKT180 Wait Code Problem
try to set D10.1 to 0
- You may not post replies
- You may not edit your posts
Forum Rules
