Hyundai Hit30s - Siemens 840C
Results 1 to 14 of 14
Thread: Hyundai Hit30s - Siemens 840C
    Registered Web.eng's Avatar
    Nov 2008
    Default Hyundai Hit30s - Siemens 840C
    G'day All,
    Got a problem with a Hyundai Hit30s Lathe with a Siemens 840C control.
    The machine had not been used for a while and when it was turned on again a week or so back, the memory backup battery was flat.
    The tech guy apparently did a re-install of data from the machines own backup which got it up and running again but now it has an issue with thread cutting.
    For some reason it seems to advance the pitch about 0.5mm each pass when thread cutting so instead of a single pitch thread you end up with a multi-pitch tapered looking thread.
    Also, each time an M19 is cycled or the spindle orient button is pressed, the spindle orientate to a different position.
    Anyone got any ideas?
    Thanks.
    Regards,
    Dave.
    Boulder Creek Tramway: www.smex.net.au/bouldercreek
    Sep 2009
    Dave
    I have 2 Hit30's that run Siemans 840D. Both were bought used.When I went to for a pre-buy inspection on the older one(1999),I noticed that the switch on the spindle was replaced.Part# 6FX2001-8AA05 R6/B3126M.The shop foreman told me that they were having trouble with rigid tapping.I assume that since this switch sits atop a toothed reluctor ring,It must have something to do with position.Hope this info can help you.Also try siemans
    https://support.automation.siemens.c...p6mcvepEO6rLYX
    Ted
    Nov 2008
    Thanks Ted,
    The switch is working fine so I don't think that is a problem.
    I have also noticed that the spindle does not seem to be running at the correct speed. For example I set the spindle running at 60 RPM and counted the revolutions while timing 60 seconds. the spindle only seems to be doing 50 RPM.
    The machine was running fine before the battery issue.
    Regards,
    Dave.
    Sep 2009
    Dave
    Is it possible some parameter was loaded wrong when the tech reloaded all the info? Maybe the spindle drive encoder? We don't have any good techs around here that I could ask,But I can check my parameters against yours if that would help.Let me know if there is anything I can do. Good Luck!
    Ted
    Nov 2008
    G'day Ted,
    Yes, that was my guess, but to be honest, I don't know where to start looking.
    Any advice appreciated though!
    Regards,
    Dave.
    Sep 2009
    Hyundai Hit30s - Siemens 840C-tooleye-jpgHey Dave
    I have our hand written instructions for adjusting the tool eye in X axis.Z works the same way.
    PM me and I can send a PDF.
  7. #7
    Registered javier1's Avatar
    Mar 2014
    Default Re: Hyundai Hit30s - Siemens 840C
    Hi Tedger,
    Where I work they have same machine as you, and now we have a problem, when we touch (X) with tool eye the value on (X) in tool Geometry is off by .188 any help please how to fix it.
    What happen was my co-worker star touch tools on wrong screen and something change.
    Best Regards
    Javier
  8. #8
    Sep 2009
    Javier
    Use the Instruction sheet I posted below.If you already now how far off you are in X,start at line 6 and change the value in T_EYE_X (1 or 2) according to the instructions.
    It's a good idea to record the parameters for the tool eye before you begin so you have a base starting point.It may take a few attempts to get the perfect value but it isn't hard to do.
  9. #9
    Mar 2014
    Hi Tedger,
    I will print this page and try to fix it.
    The page on the control that my co-worker when was (Tool eye calibration,) on one side of the screen have (probe dimensions [X: Radios])
    What is the most complicate of this operation?
    Best Regards
    Javier
  10. #10
    Sep 2009
    Javier
    My control is an 840D so it must be different from the 840C. I don't have anything that says "Probe Dimensions" [X: Radios] Nothing even close.
    Sorry
  11. #11
    Oct 2016
    Poland
    Quote Originally Posted by Tedger View Post
    Hey Dave
    hi guys.
    I have hyundai hit 8 s and cannot adjust probe figures. tried that page from DAVE but my machine doesn't have ''user data'' soft key, as per step 8. Any ideas?
    thanks
    Tom
    Attached Thumbnails Attached Thumbnails Hyundai Hit30s - Siemens 840C-dsc_0828-jpg   Hyundai Hit30s - Siemens 840C-dsc_0829-jpg
  12. #12
    Sep 2003
    Auckland, New Zealand
    From our 15s/18s which uses the 840C control, try the following
    Press "Menu Select"
    Press "Diagnosis"
    Press "Password"
    Type in the password "1111"
    Press Yellow Input button
    Press "Set"
    Press "Start-up"
    Press "Machine Data"
    Press "Cycle MD"
    At the bottom of the page will be the parameters you're after.
    1020 = Z Plus, 1021 = Z Minus
    1022 = X Plus, 1023 = X Minus
    According to my note you adjust this figure by half the difference between the programmed size & the actual machine sized. If turning the outside, if the turned diameter is 0.5mm oversize then increase 1022 by 0.25mm, If boring & the bored size is 0.5mm smaller than the programmed size then decrease 1023 by 0.25mm. I always write the original figure down so if I make a mistake I can go back close to where it should be.
    Press the "Page-Up" button the arrow button on the left hand end right below the display
    Press "NCKPO Power Off) this will save the changes & power the control off & then back on again
    Wait for the control to restart
    Press "Power-On"
    Turn dial to "Ref"
    Press the "Home buttons to reference the machine
    Remeasure the tools using the tool eye & you should be good to go
  13. #13
    Mar 2014
    Quote Originally Posted by atmosports View Post
    Press "Menu Select"
    Press "Diagnosis"
    Press "Password"
    Press "Set"
    Press "Start-up"
    Press "Cycle MD"
    Press "Power-On"
    Turn dial to "Ref"
    Thank you for you replay to my question. I will try this steps.
    Best Regards
    Javier
  14. #14
    Oct 2016
    Poland
    Thank you for your reply. I will try it. But after posting my question here I got hold of Hyundai service manual.
    1. You need one known tool, set it manually, cut and measure.
    2. Press tool eye calibration, probe down, and touch probe with that known tool. Observe that probe dimensions change.
    3. Select manual tool measurement and touch all your similar tools.
    4. For internal tools same principle applies, known id tool,tool eye calibration, touch probe,.
    Hope it helps to someone in future.
    Tom
