Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Plasma and Waterjet Machines > Hypertherm Plasma
Hypertherm Plasma Discuss hypertherm plasma machines here.
Old 02-14-2010, 10:18 PM
planebuilder is on a distinguished road
Hypertherm 1250 consumables for beginner
Jim: , I hope !
I am ready to buy a Hypertherm 1250, the decision made mostly due to your presence and help on CNCzone.
I have a few questions,
I am buying it with the hand torch, most use will be on a CNC machine but I want the versatility to remove the torch and cut some things by hand. My machine has a mount for the hand torch. I have THC.
1. I want to order consumables with the 1250 to save on shipping, the manual lists the various consumables but doesn’t give any guidance regarding selection.
For example you can cut 1/4" @ 40A/48ipm or 60A/86ipm or 80A/105ipm.
If looking for best cut quality, what combination is best.
2. At 40 amps, shielded and unshielded consumables are listed. How do I decide which
configuration to use?
3. Below 10 Ga. Is it always best to use the fine cut consumables?
Thank You for you advice!!
Old 02-15-2010, 10:37 AM
jimcolt is on a distinguished road
Planebuilder......all good questions!
In order to use the Powermax1250 on a machine.....with the hand torch you will have to defeat the trigger interlock safety circuit....many have done this...but warning you in advance, I cannot help you do it! If you use the machine torch...interfacing the plasma start is simple....pins 3 and 4 on the rear panel interface plug when jumpered together will fire the torch. The function of these pins is disabled when a hand torch is plugged into the unit for safety reasons.....we don't want a remotely controlled start signal firing a hand torch. Hypertherm has a nice easy to connect (no tools) torch system.......I keep the machine torch on my machine......and when I want to cut by hand I take 20 seconds to unplug the machine torch and plug in the hand torch. I know it is more costly to buy both.....but over the years you will save the money you spent in time not wasted. It is difficult to connect and disconnect the hand torch to a torch holder....and ensure it is perpendicular to the plate.
To answer question 1.......the best qut quality in terms of edge angularity and surface roughness is with using the lowest powered process listed in the charts. When you go to a higher powered process....expect dramatically higher speeds but more edge angularity and top edge rounding. I would cut 1/4" at the optimal speed setting in the Hypertherm manual.....48 inches per minute with the 40 Amp shielded consumables.....if I wanted the best quality in terms of holes, fine features and edge squareness.
Question 2.....I would suggest never using unshielded consumables. Hypertherm continues to produce them as they are used for applications such as 3D robotic cutting where the torch has to get into tight spots.....as these consumables are a bit longer and pointier as compared to shielded. Non shielded parts do not cut as well as shielded, and will provide shorter life as compared to shielded.
Question 3......kind of the same answer as above.....use the FineCut consumables for best quality and narrower kerf on thinner gauge material. Speeds will be slower....but cut quality is much nicer on 10 gauge (many use the FineCuts up to 1/4".....more dross is evident but edge quality is very nice).
A little advice on what to order for consumables:
1. Even if you are using the hand torch on a cnc machine.....use the machine torch shield......which is designed for the proper standoff when using a torch height control. The hand torch shield is designed for drag cutting.....so use that one only for hand cutting.
1.With FineCut parts....I suggest using the 220404 shield.....this shield extends a few thousandths past the nozzle and protects the nozzle in the event of contact with the plate...use it for both hand and machine cutting with FineCut parts.
So....what parts to buy? You will have to make that decision based on speed or quality. I use them all in my home shop....depending on the needs required for the job I am working on.
Best regards, Jim Colt
Originally Posted by planebuilder View Post
Jim: , I hope !
Old 02-15-2010, 10:48 AM
Jim:
Thanks for the insight and quick reply, very helpful!!!
Morgan
Old 05-03-2010, 11:36 AM
I am not sure what the reasoning behind the post about Hypertherm from sherrry1 was all about!
Jim
Old 05-03-2010, 12:49 PM
vishnu is on a distinguished road
what do you think will be the life of one set of consumables. Like no of pierces or the length of material cut. Please give a good insight.
Vishnu
Old 05-03-2010, 01:46 PM
I would need to know the type and thickness of material being cut, do you want best cut quality or best speed, what is the average length per cut cycle in inches, and which Hypertherm system is being used. Each system cuts at different speeds, with different quality, and my provide different life....and life is based on the above data.
If you were cutting 3mm steel and your parts took roughly 20 seconds for each cut, and you were using a Hypertherm Powermax 1000 at 40 amps with standard shielded consumables.....I would expect that you would get approximately 450 to 500 starts and approximately 9000 lineal inches of cut per electrode and nozzle change.
Jim Colt
Hypertherm 1250 evolution? planebuilder CNC Plasma and Waterjet Machines 1 06-10-2009 05:32 PM
Hypertherm 1250 problem Gec CNC Plasma and Waterjet Machines 6 05-14-2009 06:12 AM
Newbie- hypertherm 1250 ec12348 Want To Buy...Need help! 6 02-19-2009 08:13 PM
I am looking for New or USE Hypertherm Powermax 1250 Plasma Cutter newla Want To Buy...Need help! 0 12-22-2008 11:31 AM
hypertherm consumables Pure-Powder CNC Plasma and Waterjet Machines 14 06-03-2008 10:26 PM
