Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Plasma and Waterjet Machines > Hypertherm Plasma
Hypertherm Plasma Discuss hypertherm plasma machines here.
Old 01-21-2010, 05:37 PM
vjeko is on a distinguished road
pmx45 or bigger ?
I'm writing from Croatia and here Hypertherm plasma units are most easily obtained.
I'm looking for a plasma unit at the moment just to support my woodworking
jig/tables etc. building, repairs around the house and later maybe with
artistic type work/cnc in steel and stainless
(plasma may be a bit of an overkill for now but am very much looking forward to avoiding
cutting with grinding discs and like having new toys ).
Just wanted to double check - for hand and cnc applications (light work),
am I missing something by going for the pmx 45 over a larger model- eg. noticed in the specs that there's :
-no fine cut consumables
- no 90degree hand torch as standard (wouldn't even know which would be best to get)
- no auto voltage (I guess this means setting the power voltage manually - no big deal)
I'd like to avoid spending this much money and then find out I didn't spend enough
One stupid question - how does cutting square pipe work - do
you drop the current/air and burn through one side at a time ?
I'm a couple of hundred kms from the distributor, so it's a bit difficult
to check it out live - these are the models we have here - I guess
there is no new/old models of the pmx45 :
http://www.euroarc.hr/hyperterm.html.
Got to get a bigger workshop... svenakela RC Robotics & Autonomous Robots 2 08-28-2008 05:29 AM
better, bigger cnc router? jimmyaz Open Source CNC Machine Designs 10 02-17-2008 07:01 PM
The bigger hammer Stepper Monkey Benchtop Machines 7 07-01-2007 12:43 AM
sherline or bigger? landongw Mini Lathe 1 02-19-2007 03:15 PM
My New Lathe; bigger/better Stevie Vertical Mill, Lathe Project Log 61 02-01-2006 09:32 PM
