| Hypertherm Plasma Discuss hypertherm plasma machines here. |
I am posting this again here because it seems the right place to ask I need to know the Cable diameter of T100M torch machine, I can't seem to find that info in the manuals thanks |
| I put a caliper on our T100M cable today and it is .725" dia. The smallest dia. was .710" (ours is slightly out of round) I think it is probably listed as .75" dia to be safe with specs. Of course the torch tube is 1.375" dia. for standard clamping. Cheers, WSS |
| thanks for the help WSS do you know what the diameter might be if the cable is shielded? you mentioned standard clamping for this torch, do you mean standard in size?or is there a standard clamp you can buy for the torch? |
| I think it is shielded. I have only seen one type and assumed it is shielded. The torch body is standard-ish,meaning it matches a lot of torches size wise. I know some of the water cooled hi def torches are larger but the most common is 1.375" , it is the same as a oxy torch body. Here is a link to a nice aluminum machined mount on ebay: http://cgi.ebay.com/K2-CNC-Plasma-Mo...#ht_1629wt_953 Cheers, WSS |
| There is no shielding on the T100 torch leads...the Powermax1650 is a non high frequency unit...so shielded leads are not necessary. The torch info in regards to diameter and length of the body is listed in the system manual.....it is designed to fit in any 1-3/8" diameter oxy fuel torch holder. Jim |
| Hypertherm T100M Machine Torch Cable diameter | Zaher | CNC Plasma and Waterjet Machines | 0 | 01-18-2010 07:29 AM |
| Hypertherm machine torch dimensions | mag409 | CNC Plasma and Waterjet Machines | 3 | 01-04-2010 04:27 PM |
| Hypertherm 1250 with a T100M torch??? Short consumable life | Brink_ | CNC Plasma and Waterjet Machines | 18 | 01-08-2009 10:28 AM |
| Hypertherm Machine Torch | Big John T | CNC Plasma and Waterjet Machines | 8 | 04-04-2008 10:20 AM |
| Hypertherm 1000 Machine Torch Help | mattmu | Plasma, EDM and other similar machine Project Log | 9 | 12-21-2005 01:12 AM |
