| Hypertherm Plasma Discuss hypertherm plasma machines here. |
i have a hypertherm 1250 powermax on a 4x8 cnc table with the hypertherm phc with ohmic, the retaining cap i am using now is 120928with the sensor wire threaded between this and the shield , should i switch to retaining cap220061. thanks |
| For the ohmic contact function to operate with your Sensor PHC height control...you need to use the 220061 retaining cap that has the wire connector. This allows the height control to make an electrical connection to the shield....for accurate plate surface sensing. Jim |
| okay ,thanks, when gorilla set it up they made a loop in the wire and put it around the thread on the retaining cap and the shield and said not to thread it tight, is there a connector i need to put on the wire for it to connect on to the retaining cap, thanks |
| Retaining tabs | ssozonoff | SolidCam | 2 | 01-05-2009 03:43 AM |
| Dividing a solid and retaining both sides | Cammotion | UG NX | 3 | 08-02-2008 01:16 AM |
| retaining thread lead | argomch | G-Code Programing | 2 | 09-24-2007 06:22 AM |
