Originally Posted by
PlasmaGuy
Jim,
Here is a question for you. The material is 1/4" mild steel. I cut this using 60A consumables. Air pressure is correct.
What is causing this excessive build up? Is happens on straight as well as
circular cuts?
I bought this machine new in April of 2003. S/N 59266 1650-000666
Jim, as the components in this machine age/wear will I see any signs of decreased cutting performance? Or will it just stop cutting "cold turkey" so-to-speak. This machine has had two boards replaced, under Hypertherm's excellent warranty I might add too.
This machine has performed solidly since new outside of these two board issues. The 1650 had just been introduced so this machine was relatively new I was told??
Thanks,
Tom
